Lsx block 6 bolt heads and boost
Old 02-18-2015, 08:30 PM
dragrex's Avatar
Default Lsx block 6 bolt heads and boost
Just checking in with everyone to see how much boost they have put through a lsx 6 bolt combo without pushing water/blowing head gaskets. I know the tune is important and I know people have seen 20 plus psi with 4 bolt set ups. Just trying to see how much more reliable a 6 bolt combo is in everyone's experience and what head gasket you ran.
Old 02-18-2015, 08:53 PM
SHAWN@PRACETECH's Avatar
the lsx six bolt heads aren't much better than the oem ls7 castings. they are still a lightweight casting. we have seen 24 psi on the set on the COPO Super Stock engine. they seem to be holding ok using a cometic gasket. I personally don't think that setup would handle a whole lot more.
Old 02-18-2015, 09:00 PM
4bangermustang's Avatar
Believe Mana made over 50#'s on a lsx 6 bolt BLOCK, with nice aftermarket heads.
Old 02-18-2015, 09:04 PM
6 Second Club Moderator
LASTLS1's Avatar
Four years 36 lbs never pushed a drop of water. Tons of passes.
Old 02-18-2015, 09:14 PM
dragrex's Avatar
Do you have a o ring block/head combo, copper head gaskets?
Old 02-18-2015, 09:17 PM
Tiago's Avatar
lol very nice.
I ran 30lbs for several years, never pushed water either.
Old 02-18-2015, 09:18 PM
dragrex's Avatar
Originally Posted by Tiago
lol very nice.
What heads and head gaskets did you use?
Old 02-18-2015, 10:45 PM
we made 55 lbs of boost on Phil's LSX 438 with ETP LS7 heads, that was copper head gaskets and double orings
Old 02-19-2015, 06:29 AM
dragrex's Avatar
That's crazy! At what point would you put any o rings on the block?
Old 02-19-2015, 07:37 AM
LS1Tech Sponsor
hellbents10's Avatar
We had good luck with cometics at 35psi running 7.0@192-195, Going 200+ required the switch to copper though. Going 220+ better heads are required.
Old 02-19-2015, 08:56 AM
scottywheels's Avatar
Love love love your car
Old 02-19-2015, 02:16 PM
Tiago's Avatar
simple cometics, nothing special, old school ETP 255 6 bolt setup.
Quick Reply: Lsx block 6 bolt heads and boost
