Quick spool turbo on ls3, bw s366?
Hey everyone, I've got an 08 C6 ls3 and I'm looking at doing a Budget custom rearmount single turbo setup on it, I've read through the rear mount threads and have a pretty good idea of what I need/want.
Question is how fast will the BorgWarner S366 spool on a stock LS3? Looking at probably T4 or T6 housing 1.1a/r for better spool. Hard to find info on anyone using this turbo as a single, Is it too small of a turbine housing for around 700whp? Will it be choking up top?
I'm looking for full boost in the 3k rpm range or close too.
Thanks for the help in advance.
You'll run out before 700whp with an s366. You'd likely see about 650whp absolutely maxed out. The best bet would be to go with a good billet 472 like a batmo or similar and 83mm turbine. t4 1.0 a/r. That would spool very well and make the power you're looking for. If you need to go cast for budget reasons a 475 will work it'll just lose even more spool and definitely stay away from the 1.32 96mm turbine units that everyone has for cheap.
Jack
Jack
So what kind of spool differnce would there be in the s366 vs the s475? Given I'm using the 1.1 t4 turbine housing?
I'd really like full boost by around 3-3.5k?
It'll spool a bit slower, but you wont reach the power goal with the s366, so its kind of pointless to compare against. the 83mm turbine t4 1.0 would spool very well.
Jack
Jack
s366 is good for 600 hp at 20+ psi not less . ls3 will reach 600 hp at 8 psi or less . so the turbo will choke and overheat the air. he needs a bigger turbo in the range of BW S400 or Garrett Gt42.
sorry but a turbo ls at 600 hp seems like a lot of wasted cash
go 800 or go small blower or Nitrous at that HP level to save some $$
go bigger or don't go at all and run the right turbo?
I'd go with a couple of oiless comps and a more lofty 800 hp flow capacity
or twin s266
or twin s266
Jack
Well my main goal for the car is to have a fun street car, not really looking to hit a particular number atm. Really would just like to see around 600 max of 700 to keep it fairly reliable.
I came from the turbo import world and I really love the feeling of a quickspooling setup over a laggy max power one.
I'm mainly looking for insight on how fast these turbos will spool with a manual trans in an ls3. Most of the dynos I can find are autos which change the spool characteristics.
Reason I'd like to go turbo is most corvette guys go supercharged or nitrous which is definitely the easier route but Id like to be a little more unique. And Turbos sound oh so wonderful. Appreciate all your help.
or twin s266
or twin s266
F1 wheels seem pretty good. Flow well but the 68mm is alittle on small side for 6.2. The 7875 would be abit better match for a 6.2. Would spool fast with a tighter ar housing option
To the OP...
I'd want a larger exhaust wheel on an LS3. Instant spool on an LS3 will be pretty pointless, it will just spin tires. The S475 T6 1.10 87mm exh wheel turbos can be had for $600 shipped now. Hard to beat that price!
http://www.ebay.com/itm/121290566846?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
So far the plan is:
turbonetics 7875 .96 a/r
BTR stage 3 turbocharged cam 230/235 114+4
Tial 44 wastegate
Tial Q BOV
stock exhaust mani's
2.5" heatwrapped hotside back to turbo
2.5" stainless coldside to intercooler
Treadstone 3.5" intercooler
3.5" alum piping from intercooler to TB
Turbowerks scavange pump
tap'd valve cover for oil return
Any input?
Tial 44 wastegate
Tial Q BOV
Any input?
Jack
So far the plan is:
Tial 44 wastegate
Tial Q BOV
Any input?
Tial 44 wastegate
Tial Q BOV
Any input?
So I'm guessing I should contact someone and get a cam spec'd out, the only ls3 turbo specific cam I've seen is the Tick line. I was hoping to get a cam that I could throw in and make good power N/A, Which this cam is very close to the spinmonster spec'd N/A cam, but still make good power once I go turbo.
