another 69 camaro jy 5.3 turbo build
Well I've been lurking for a while now getting ideas for my own 5.3 turbo build. I sold my drag car and bought a mostly stock 69 camaro. Car is a nice driver with a good five footer paint job on it. Nonoriginal sbc and m21 4 speed. Which I promptly pulled a week after I bought the car and sold for 1500.
Here's my list of parts so far.
100k mile 5.3
Sa timing chain
New stock rings
New rod bearings
Ls9 head gaskets
Forced inductions s400 turbo
Brute force blower cam
Chinese head studs
Comp valve springs
Jegs push rods
Treadstone ic
Persicion bv
Tail wg
Fic 95lbs Bosch injectors
Duramax map sensor
Magnafuel 4303 pump
Magnafuel fpr
2.5" mild steel tubing and some flanges
Plan on running e85
And picked up a tci powerglide and 10" converter from a buddy of mine at a real good price.
100k mile 5.3
Sa timing chain
New stock rings
New rod bearings
Ls9 head gaskets
Chinese head studs
Comp valve springs
Jegs push rods
Treadstone ic
Persicion bv
Tail wg
Duramax map sensor
Magnafuel 4303 pump
Magnafuel fpr
Plan on running e85
Made some progress this morning on my manifolds and hot side piping. Just trying to find the best spot for the turbo, don't want to cook the paint off the hood or fefender.
Pass side manifold.
.... And drivers side with a little bit of the piping installed.
Kinda of a tight got but I'm trying to run the piping in a way so that i can have just one really well positioned waste gate.
Pass side manifold.
So did you just cut off the upper half of the drivers side manifold? Just exhaust pipe welded on or something else? Looks good so far man, have you considered keeping the hotside divided and running two gates? Supposed to spool faster but I've never seen back to back results on a v8.
Yup there just truck manifolds flipped up side down and hacked apart. I used some 2.5" ms tubing to piece them back together. I'm going to try to keep it divided as far as I can and just put the waste gate at the merge near the turbo if there's room, I don't really want to buy another wg if I don't have too, those things aren't cheap!
I've already got like 3/4 of the hot side piping done some I'm pretty much committed to 2.5" although looking back I kinda wish I would have gone a little bit smaller pipe though. I do appreciate the suggestion! Thanks!
Thanks!! Before I decided to go ls turbo i was looking into BBC wanting to make around 1000hp, that was going to cost at least 10k, after a little research I fond out that u could make that same power with a 5.3 and a big single turbo at almost half as much and be very street able. That decision was a no brainer for me! The manifolds are off an 04 Silverado 5.3 non egr.
Looks good! I wish I would have got the polished turbo. What are you running for a driver's side manifold? Does it clear your brake booster? The upside down truck manifold almost touches my booster so I'm going to have to put a smaller one on our maybe convert to hydrobooster.
