Phase 2: Hairdrying
Old 02-28-2015, 06:44 PM
tiresmokinV8's Avatar
Default Phase 2: Hairdrying
Ok Im done with nitrous refills, time for boost!
Plans are to pull the engine to get out those precious very first set of Stainless works headers ever made and make room for custom turbo manifolds. With the engine out Ill send the convertor to be restalled for the new setup. Pull the pistons and open up the ring gap. Add LS9 head gaskets and ARP head studs.
Parts I have or have ordered.
Precision 7675CEA
Precision pw46 wastegate.
Turbosmart race bov
Devils own stage 2 meth kit
Treadstone 1235 intercooler
Ls9 Gaskets
Arp head studs
My buddy works at Big 3 Racing and will be fabricating the hotside.
Old 03-01-2015, 02:57 PM
Ordered speedhut gauges today. Trans temp, boost and fuel pressure. If your looking for gauges id recommend them. Very innovative styling and wiring up. Completely custom.
Old 03-05-2015, 05:21 PM
Found ARP headstuds new for 276 shipped to my door off ebay.
Old 03-05-2015, 05:59 PM
IronBlocked's Avatar
Truck looks good man, subbed
Old 03-05-2015, 07:43 PM
Tear down has begun and once the water lines in my detached garage thaws the truck will get a much needed washing.
Pressurized the cooling system and it bleeds down from 15psi to 0 over a few minutes and you can hear the water sizzling/leaking but I cant find where. Pretty sure its not the hoses but it is on that side somewhere.
Old 03-05-2015, 07:51 PM
SSZ
SSZ's Avatar
This should get interesting.
Is that a ZR1 rim on the front of the truck?
Old 03-05-2015, 07:55 PM
Yup replica 18x9 up front and i havent put the rears back on but theyre 19x11
Old 03-06-2015, 02:44 AM
Meth Sled's Avatar
Sub'd as well! Clean truck!
Old 03-06-2015, 07:08 AM
willizm's Avatar
You'll love that turbo. What size downpipe are you putting on it?
Old 03-06-2015, 07:22 AM
Im really hoping that I will, I hope it doesnt choke down the 6.0. As for downpipe Im going to do whatever it takes to fit 3.5" from turbo to out the back. Only tight spot will be at the firewall.
Old 03-08-2015, 07:14 PM
Got quite a bit accomplished this weekend. My Brother came over and we got the engine out.
Took out the underhood insulation since it was beat up.
Old 03-09-2015, 05:10 AM
m8w6r77's Avatar
the 19x11 fit on the back with what backspacing? lol. I have the first gen blazer.
Old 03-09-2015, 08:20 AM
Theyre meant for c6 vettes so whatever backspacing might be on that plus a 3" spacer, gets it to sit centered in the wheel well.
Old 03-13-2015, 04:33 PM
Haha thanks. Gave up alcohol for lent so that kept the spills down hahah. Took about a day and a half to get it all out plus nitrous out. Could have done it in one long day if I wanted Im sure.
UPDATE.
Got the engine down to shortblock.
TSP pushrods are holding up fine.
Just doing an oil change I swear HAHHA
My new 80lb Siemen Deka Injectors came in.
Old 03-17-2015, 09:11 PM
Installed my 80 lb injectors tonight. Not sure if I did the short to long conversion correctly.
Made some spacers at work on the lathe
All I can guess is that because of the opposite angles of the injectors per bank its causing the rail and injectors not to fit perfect anymore.
Besides having to slot the 4 bolt mounts which is expected, the injectors are also not centered. One side is centered but I did that side first. The other side I had to push the injectors over to get each in the hole and once bolted down you can see they are centered but I hope its ok.
Not centered
Centered
Old 03-20-2015, 09:31 PM
Radiator came in from CPW.
Also my treadstone intercooler, Turbosmart 50mm BOV, and Ls9 head gaskets
Glowshift 3 gauge pillar pod
Cut up the front end some to get the intercooler to fit.
Old 03-21-2015, 10:26 PM
I cut too much out but once I mount the trans cooler under the intercooler in the bumper area Ill reinforce the frame more.
Old 03-24-2015, 08:18 PM
Followed a fellow s10 builders thread and decided to buy the Glowshift pillar pod to mold into the stock pillar trim.
With the other end even this is how the dash end looks. Super close fit hahaha.
Cut off both ends and put it onto the factory trim piece while it was installed and marked exactly where I wanted it.
Sanded and cleaned all mating surfaces
And JB plastic welded it together.
Tomorrow Ill use the Bondo bumper fix epoxy to mold/feather in all the edges to make it seamless.
Old 03-25-2015, 08:27 PM
Speedhut gauges came in! They have some amazing quality cant wait to use them,
Comes with all the sensors and a harness for power to all 3 so thats plug and play so you dont have to run separate power to each one.
Transcooler is half mounted. Itll raise slightly once I make up some bottom mounts.
Old 03-26-2015, 05:55 AM
JAX04's Avatar
clean truck, you every weigh that thing?
Quick Reply: Phase 2: Hairdrying
