Edelbrock Pro Flow Vs. Holley mid or hi rise intakes????
best for what really ? They'll all make great power, but hopefully the link below will get some more empirical data in the coming days/weeks
https://www.facebook.com/onthedyno/p...13433065363224
I also run the Pro Flo on two of my cars. I really like the intake for the price! If you have the extra cash the Holley High rise looks a little nicer in my eyes. But as far as power goes I would bet there is not much difference between the Holley high rise and the Pro Flo. Unless someone has hard evidence of this?
I know if I was making and selling an intake that I knew was head over heels better than the competition...I'd have tested it and be shouting about it. It would help sales massively ( if it really was that good of course )
Since you are putting it in a truck clearance should not be an issue.
For mild boost any of them should work.
For higher boost I think I would go with the Edelbrock. Only because it is one piece and would be less likely to leak around the seams.
Just an opinion I have no data to back it up.
The FAST intake is horribly expensive. I have one (bought used) on my NA car. The shell is very thin. And it's a two piece affair with a big long snake of a gasket between the halves. I had issues with mine leaking NA.
I like the PRO flow on my Nova. But I can't speak to hp improvements over the truck intake. Although a buddy picked up 30 hp on his turbo car.
GM chose the Holley hi ram for the COPO Camaros. In that arena, factory race cars, I think it speaks volumes. Those cars run high 8's NA.
Ron
Ron
Ron
Ron
In terms of two-piece issues, the Hi-Ram has been through quite a few high boost situations and has held up flawlessly. Just the other day the H8RMKR Vette made 1500 horse through one on 32 pounds of boost. Can this be an issue? Yes, 100%. But I believe the Hi-Ram is a bad **** and will pull through
Old thread but I've been looking into this same thing for my TT boat. The cost of the Edelbrock is eaten up if you get the Edelbrock fuel rails as the Holley costs a little more but comes with fuel rails. All in all, the Holley will be $20 cheaper when that gets factored in on current pricing from Summit or Jegs IF you go with black. The raw finished Holley will be about $60 cheaper than the Edelbrock.
Here's a great article on all available intakes. 4hp difference between the two.
http://www.hotrod.com/features/1507-...ifolds-tested/
So whether either is worth buying, depends on the rpm range you want to operate in.
He needs to have an idea of his lower unit ratio & his prop RPM. He has to set that according to mass & hull inertia resistance through the water (drag).
The more efficient his drag the better here, but it will respond to the load, what ever it is, set up properly.
Intended usage is imperative here.
This deserves it's own thread for further analysis.
One of the problems I found with the article was using the same cam/head combination.
I understand the intent was for bolt on gains. However you don't know if the cam or heads were the limiting factor.
If your engine is designed with a specific intake, head, & cam and is optimized then you might well see different results, larger gains, than those tested.
Personally I think the ProFlow & HighRam are better for larger displacement engines than the one in the test. Also larger displacement will bring the RPM range lower.
There have been several builds on here with the HghRam that showed impressive results.
I'm using the HighRam on my 454 build.
Just my $.02.
Just my $.02.
