Cheap China single dyno tests
Old 03-03-2015, 01:06 PM
stevieturbo's Avatar
Default Cheap China single dyno tests
Interesting read
http://www.gm-efi.com/tech/budget-bo...turbo-testing/
Old 03-03-2015, 01:19 PM
Lawhead's Avatar
Figured they'd use a "Stock" 4.8 with the normal little things vs a built motor
Cool read either way
Old 03-03-2015, 01:31 PM
66Chevellelq4's Avatar
As interesting as that is, i would have loved to see them incorporate an electronic boost controller and command a specific psi and run the test again and see how the two turbos compare psi for psi. Great info though! Thanks for the link
Old 03-03-2015, 01:44 PM
NemeSS's Avatar
Sounds bout right.
Old 03-03-2015, 02:40 PM
FrossB's Avatar
Is that GT45 they used the 69mm verson? Maybe I just missed where they discussed its size
Old 03-04-2015, 04:47 AM
jay_rich's Avatar
Yes the DNA Motoring is a 69mm unit. Pretty cool comparison between the two units with different turbine wheels.
Jay
Old 03-04-2015, 06:29 AM
69-chvl's Avatar
I'm assuming the CX turbo had a real small turbine? They didn't list the specs.
Old 03-04-2015, 08:31 AM
jay_rich's Avatar
The CX racing is a 65mm turbine. Shows what kind of bottleneck those small turbines have even on a 4.8L. Would have been more interesting to see with a stock motor with a stock or even up to a ls6 cam. See what the results in back pressure would have been
Jay
Old 03-04-2015, 08:42 AM
A 65mm is still a small turbine though, most would be using a pair of those with twins and even on say a 6.0 with twins, a 65mm turbine isnt massive by any means
Old 03-04-2015, 09:33 AM
FrossB's Avatar
Jay
That's what I thought. I have the DNA Motoring GT45 and was surprised to see it give better numbers than the tested "76mm" But then again they didn't give the entire specs of the "76mm" haha
Old 03-04-2015, 10:27 AM
redss82's Avatar
the 76 is the ptrim style that everyone sells exhaust wheel is a 65mm the gt45 is a 77mm exhaust wheel
Old 03-04-2015, 11:32 AM
69-chvl's Avatar
CX Racing also has a 76mm turbo with a larger wheel...we will never know if they used the small wheel or larger wheel (we can only assume it was the smaller).
Old 03-04-2015, 11:46 PM
redss82's Avatar
you can tell just by looking at that its the standard small wheel the bigger 76 they call it a gt45r its physically bigger than both the 76 ptrim and the gt45
Quick Reply: Cheap China single dyno tests
