thoughts of my turbo option billet s476 1.10 92mm turbine
Car is a 6speed the the huron speed V2 t4 kit stock cube ls1 built bottom end 9.8.1 compression ported heads flow 300 cfm custom spec cam fast 90 intake with fast 90mm ported wondering how and if I picked to big of a turbine wheel that it be laggy pull hard but loose alot on shift ant imput will helps thanks
