LMG/317 corrected airflow lbs/min?
Old 03-08-2015, 11:51 AM
abrown0788's Avatar
Default LMG/317 corrected airflow lbs/min?
Done a good bit of searching but haven't really found what I'm looking for through mobile searching. I'm trying to find out the corrected airflow lbs/min so I can look at different turbo compressor charts.
Through HpTuners my Lq4/243 dynamic airflow ranges 32-40lbs/min. Is this the same as corrected airflow used in these charts?
I have a LMG 5.3/317/6.0 cam/DoDvvt delete that I'm throwing in my 89 Mazda B2200. I'm trying to calculate the calculated airmass so I can map out a turbo setup for it. Sorry if this sounds newbish. Thanks for any info
Quick Reply: LMG/317 corrected airflow lbs/min?
