Scrapyard S10
Old 07-18-2015, 01:49 AM
  #61
Cyrperformance's Avatar
Hopefully it is a good cam! We will find out by Sunday as we did some quick wiring and have the motor turning over and will have the pcm and OBD2 port wired tomorrow. Tried firing tonight but found the fuel pump is dead.
Old 07-18-2015, 09:45 AM
  #62
Forcefed86's Avatar
Few companies shelf cams are VERY similar to that grind. I don't think it would be ideal anywhere near 7200 rpm. That cam has 2.5* of overlap @ .050 and maintains low overlap at TDC. If you're backpressure isn't through the roof, I think it will work well for what you're doing.
Too much emphasis on cams IMO. Any decent lift duration cam will make enough power to bend the rods. You are talking a 20-30hp difference at most and power range shift of 400-800 rpm in most cases when comparing similar cams.
Heres a couple...
http://www.herbertcams.com/hercls280...4-lobe-center/
http://pcmofnc.com/index.php/perform...2x-050-113-lsa
Old 07-19-2015, 08:04 AM
  #63
Video of the first start up completely stock, just the 80lb injectors in. No tuning done, basically stock file (injector settings done for bigger) running 2bar SD.
Old 07-19-2015, 08:11 AM
  #64
Here is the second video with the new cam installed. No tuning done yet but she fired right off.
Old 07-22-2015, 08:07 AM
  #65
First driver side header is gone and new one is almost done.
Old 07-28-2015, 09:16 AM
  #66
Radiator is in, need to build upper hose. Front end is back on, getting ready to finish up the wiring then test drive.
Old 07-28-2015, 11:55 AM
  #67
DavidBoren's Avatar
Sweet. Can't wait for the first burn out video. Good job, man.
Old 07-28-2015, 11:57 AM
  #68
Thank You kind sir, hopefully this weekend she will be moving around.
Old 07-30-2015, 10:29 PM
  #69
Wiring was pulled and wires not needed were de-pinned from VCM
Old 07-30-2015, 10:33 PM
  #70
After wiring was put back together and in place.
Not the cleanest wiring job, but it is all away from any exhaust heat. Next time I would rather make the harness a complete standalone for the engine.
Old 07-30-2015, 10:38 PM
  #71
Picked up this sweet ride, yes those are sweet 22" rollers!
2002 Tahoe 5.3 4WD complete, minus broken windshield and bent body panels. Short block has roughly 10,000 miles on it and everything works.
Old 08-01-2015, 08:26 PM
  #72
So two new headers, which makes it the third one for the drivers side and turbos are finally mounted with feeds and drains. Wiring should be wrapped up tomorrow, just need to sort a dash (someone smashed it to pieces), you know who you are! ��
Old 08-03-2015, 01:56 PM
  #73
Fuse box mounted, ignition and starter wired, pile of wires left over (must be for wipers and horns) that need to be cut out i would say. VCM mounted, just needs a dash. Pigtails for trans that were cut off. So close we can smell the rubber!!
Old 08-03-2015, 05:20 PM
  #74
DavidBoren's Avatar
Good to see progress. Keep it up.
Old 08-03-2015, 11:50 PM
  #75
So here we go, shifter is in and works (25yr old Hurst TH350 Quarterstick, doesn't go to first but who needs first), wastegates are back on. go to fire it up and starts, runs rough for about 4-5 seconds then shuts off. Restart, runs for 1-2 seconds then shuts off. Really weird that it ran (very rough) with no O2 sensors or IAT and now with them on and working it will not stay running. Maybe something in the wiring we missed but I think it is in the tune files. Complete mental breakdown
Old 08-05-2015, 08:41 PM
  #76
https://www.youtube.com/watch?v=G0Ev...ature=youtu.be
She runs and drives. Bad IAT!!
Old 08-06-2015, 10:59 PM
  #77
Charge piping welded up and installed with blow off valves.
Old 08-06-2015, 11:02 PM
  #78
Started frame work for new dash.
Old 08-07-2015, 09:25 PM
  #79
Downpipes built and wrapped.
Old 08-14-2015, 12:15 PM
  #80
89C1500's Avatar
great build!! keep it up!
Quick Reply: Scrapyard S10
