What cam should I use with my twin turbo 5.3
Old 03-10-2015, 06:43 PM
Slonomo99's Avatar
Default What cam should I use with my twin turbo 5.3
I'm building a 5.3 10.1 compression with twin 76mm 1.15 ar turbos getting the heads ported for it now and wondering what cam and springs I should use. I'd like to shift around 6500 and running a 3900 stall
Old 03-10-2015, 08:35 PM
nastychevelle's Avatar
Custom should always be the answer but if your looking for a shelf grind a BTR/LJMS Stage 1 cam or a Tick Stage 1 Turbo Cam should be close.
Old 03-10-2015, 09:35 PM
LS1NOVA's Avatar
Custom. Will need some spool help or use LJMS stage 2 and a 100 shot.
Old 03-11-2015, 02:38 AM
sahwan's Avatar
Twin 76 😳😳
I think you will need btr turbo cam stage 3 or 4 because you use very big turbos for 5.3
Old 03-11-2015, 08:24 AM
toytech93's Avatar
Sounds like you'll need a special grind just to get that thing to spool up and a transbrake!
Old 04-12-2015, 05:27 PM
Slonomo99's Avatar
Thanks for y'all's replys I sent the turbos back and got smaller ones. I called little johns motorsports and he sold me everything I need for it
Old 04-12-2015, 09:53 PM
ls G-Body's Avatar
Default info
Wondering what size turbos you went with, and what camshaft are you using?
Old 04-13-2015, 11:17 AM
DHR Darren's Avatar
Funny how many don't think 76's will spool on a 5.3, get the RIGHT converter, tune and camshaft and it will be up on the brake quickly.
Quick Reply: What cam should I use with my twin turbo 5.3
