Help with my LQ4 Build
Hey Guys,
So here is my long story short.
Bought a 5.3 LS was told the bottom end was good, so plan was to just leave it alone. Bought a 02-04 Z06 cam, a set of ported 243 heads, and will be adding boost to the equation. Only problem was I tore apart the motor and the bottom end was NOT good. So, I decided to go all out, do forged internal on the motor except the stock crank which I am told is good for a fair amount of horsepower. On my way to the engine builder I planed to bore it while I was there to 5.7, however he had a 6.0 LQ4 sitting around that he said he would sell to me for $100.00 which is way less the machine work to put the cubes in my 5.3.
SOOOO my questions are as follows:
1. With boost, where will I be at compression wise on a 6.0 with a multilayer head gasket and boost? I want to run 91 octane.
2. Will the z06 cam be good for my turbo build?
3. Is there anything I should do while I have the motor completely disassembled.
This is all going into a 1973 240z with a t56. Use will be force mostly street, but want it to take abuse as the track as well.
Thanks!
Thanks!
what is the thickness of the head gasket? 9.5 to 1 is stock c/r for a lq4. which will work fine on the boost. im going to see how much boost my lq4 will take. rolling the dice. lol. I have seen a few guys run the z06 cam but a custom grind will do wonders. head studs and valve springs is a good thing to upgrade. good luck on your build.
I have the lq9 which is the same block and I got a 10:1 (I used stock truck 317 heads to do so) with a f1 procharger and its great, I did go with the blower cam from brute speed (Bob is a good guy and can really help) and I love it (sounds mean and everyone says it sound great). I would def do head studs and valve springs and I did a alky kit with mine just because you never know when you could get bad gas and I like my engine (big safety devise while using pump gas)
Make sure to replace the pilot bearing on the crank (easy to do when engine is out and cheap $10)
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
