Powerdyne bd-11a 500rwhp
I picked up a Powerdyne bd-11a supercharger yesterday. Im planning on putting it on my 2000 Formula M6. I will be only doing around 6psi out of this unit. Currently I have 243 Heads, Ls6 intake, XR265-15 Comp Cam, Pacesetter Lts, and 3.5 Catback. My goal would be around 500RWHP with the Powerdyne installed. I think I should be there if I add the Powerdyne since I should 375-390Rwhp N/A. But, I hear that Powerdyne units arent efficient so just want to get some opinions.
Get rid of it. Before I saw the light and realized the benefits of the LS motor, I was a Ford boy and bought a PD supercharger. Long story, it failed, and when I sent it in for warranty they denied the warranty. They had been bought by another company and voided all warranties for existing customers.
http://mustangforums.com/forum/5-0l-...powerdyne.html
Like SM105K I had a few Foxbody Mustangs. One was a BD11A equipped car. The blower was upgraded by a shop that I think is still around. That thing still sucked. Mine didn't fail, it simply couldn't make the steam that other blowers could. I got the whole setup for $900 from a buddy who got a DUI. If not for that fact I'd have saved up for a Paxton Novi 2000.
Do yourself a favor and sell the Powerdyne unless you got it for SUPER cheap. If you had done research on it you'd probably have skipped buying it and saved up for a Procharger or gone with a Nitrous Plate Kit.
I paid $400 for the supercharger kit. Its actually the kit from 04 F150 5.4 a friend of mine totaled. I heard before that this units were pretty bad but my friend needed some money so he gave me the powerdyne for $400. I been doing some searching and I can get brackets and other parts needed for it to fit my car but it probably wont make good power gains if any. Its an ok unit if you have a stock engine and arent looking for more than 100hp gains. From what I read, the problems with this is that they are easy to overspin (around 40,000 rpm max). With the set up I have now if I shift at 6,400 rpm I will be spining it at around 47,000 rpm. So Im not sure if I would be making any boost spinning the supercharger at 40,000rpm max. I would be happy if I could make 500rwhp with the powerdyne and my other mods.
My opinion is that you should save yourself the headache and try to sell and turn a buck on the Powerdyne. Once you find an LS1 F-body bracket, source the hardware for install, get the crank pulley, a belt, hose / tubing to the TB, a bypass valve, injectors, 255 fuel pump and a re-tune you'll be into the kit for how much? Then you'll dyno the car and make the same power at 6 PSI that I did with a 306 SBF at 11 lbs years ago but you'll have a heavier car.
You should sit down and make a spreadsheet with everything you'll need to accomplish this install and hopefully (but most likely NOT) make 500 RWHP.
