76mm T4 turbo on 5.3?
Local 1/8th mile 275 Factory Street class I'm looking at is limited to stock block and T4 76mm turbo max. I've been planning to do a stock bottom end 5.3 for a while now but was thinking I would be running a T6 76mm or 88mm. Can the T4 combo work well with a 5.3 without too much backpressure? Would like to run E85.
Thanks,
Chuck
Thanks,
Chuck
I am running a S480 billet T4 with a 347 on E85. A T4 can make plenty of power without back pressure issues if the combo is right. How much power do you need to make to be competitive in that class? Any power goals?
Restricted User
Stock48 runs a T4 billet 76mm on a stock bottom 6.0 and runs 5.20s @ 3400 lbs if I remember right. A T4 on a 5.3 would be much less restricted on the turbine, you'll be fine.
Sounds good. Thanks for the response. I'm still a few months out before I purchase the turbo, just wanted to make sure I'm on the right track. I was concerned that the E85 would cause more backpressure. I'm gonna start off with truck manifolds, does 2.25" crossover pipes sound right?
