PT3000 A2W intercooler question
Old 04-06-2015, 12:11 PM
TRIXLSXSUPRA's Avatar
Default PT3000 A2W intercooler question
Just a real quick question for those with experience this is my first large A2W set-up w/o a heat exchanger (5 gall ice tank instead)
Was just wondering if it matter how the inlet/outlet for water supply are situated.
Is it best to have them vertically mounted like this:
Or horizontal like this:
Old 04-06-2015, 12:31 PM
4bangermustang's Avatar
Does not matter. Just use big lines like the intercooler should have on it. My 3k uses -20.
Old 04-06-2015, 02:24 PM
Meth Sled's Avatar
Like stated above, just make sure the flow's there to get lots of volume of water moving through it. Sweet build, got a build thread somewhere?
Old 04-06-2015, 06:15 PM
Thanks for the quick replies guys!
Here's the link to the build thread please check it out and lmk what you think
https://ls1tech.com/forums/forced-in...ag-radial.html
Sounds good the guy i bought the A2W and tank from gave me some -20 fittings and i believe the tank had 1 or 1-1/4" NPT's on it that should be enough w/ the Rule 2000 pump inside correct?
Also sorry if it's confusing but the black 5gall tank you see is the fuel cell the water tank will be placed about 15-20 ft from the A2W in back between the tubs here:
Old 04-06-2015, 07:29 PM
Here's a quick pic of the A2W and 5gall tank w/ -20 fittings just need to figure out the tank side of things
Old 04-06-2015, 09:09 PM
Meth Sled's Avatar
Man that's an awesome car! Can't wait to see it come together, good luck!
Old 04-07-2015, 12:07 AM
should be ok with that pump, looks like a short run. But if it runs into an issue, you can switch it out for the bigger ones.
https://ls1tech.com/forums/forced-in...g-results.html
Old 04-07-2015, 03:22 PM
Thanks for the link!
Old 04-07-2015, 09:02 PM
Shearer's Avatar
Switch to the Rule 3700(14a) and a larger water tank.
Old 04-10-2015, 10:52 AM
Thanks for the suggestion i'm actually consdering selling this set-up to go straight M1 now after many people had suggested since it's a dedicated drag car......less weight and simplfied plumbing is a nice bonus as well
Quick Reply: PT3000 A2W intercooler question
