My car is making this sound ???
If you're making 2psi then your wastegate line is NOT collapsing. It will have pressure in it at that point. Have you checked your wastegate/s for binding? I had a wastegate that would stick open intermittently and keep my boost around 2-3psi. I lubed the shaft with anti seize and it fixed the problem.
