What size injectors should I run. need advice
I'm building a ls2 416 ci with ls9 heads and a x275 turbo that is capable of over 1500hp. What size injectors should I run?
This is the problem I'm facing. Running a split tank setup and want to run 91 on the street and 112+ on the track. So not sure what size is right
