turbo too small? for twins on 418
hello guys, i went through my storage and i found a turbo that i bought several years ago for my dsm. the turbo is a t3/t4 garrett ballistic .
the turbine housing says .63, the compressor says .60
it was supposed to make 450 rwhp on a dsm. ( thats what they said when i bought it)
if i bought another one if these, and did a twin turbo setup, will theses work on a 418 cubic inch motor??
want to make 900 to 1100 rwhp
If it was supposed to make an upper limit of 450 on a small motor with higher boost, not a hope in hell of them making 900 on a large motor with lower boost.
I'd go bigger or forget about it, that one will choke it
if you have a goal of 600-700 at the tire you'll be ok, but don't plan on revving it to the moon or you'll choke it off with back pressure
I agree you will be pushing these to the max and probably will choke it. Your further ahead selling it and going bigger
These generally have a 55-59mm inducer compressor and similar 50's mm exducer turbine wheel. Definately smaller. You'd be better off with a larger turbine ratio if possible, .81-1.00 range.
They couuuuld work ok for 600-700 hp. Seen guys use these on their sbc's 305-350" motors. Bolt on L98 thirdgen with similar t3/t4 hybrids made enough on 10-12 psi to trap 115, which aint bad gain considering 100-103 mph is common with bolt on only.
