lq4 turbo help
Old 04-30-2015, 01:32 PM
ts10's Avatar
Default lq4 turbo help
I have an lq4 completely stock except a comp cam 54-480-11 cam and springs to match. 2" Longtube headers rear mounted 76mm on3 turbo with 2.5" intercooler piping. My problem I'm having is when u crack the throttle the intercooler boots suck flat. I pulled the inter cooler boot off and the turbo is moving air as it should and there is nothing blocking my intercooler or tubes . There are no exhaust leaks and no boost leaks on the cold side. Any ideas?
Old 04-30-2015, 02:11 PM
turbo lemans's Avatar
maybe cheap intercooler boots?
Old 04-30-2015, 02:28 PM
Meth Sled's Avatar
That'd be my guess. Weak/thin boots that get sucked in by vacuum.
Old 04-30-2015, 02:30 PM
jrpimp00's Avatar
Post pics if possible. Also, could be too long of a cheap boot. If your pining is close enough to the IC outlet it shouldnt suck closed
Old 04-30-2015, 03:05 PM
ts10's Avatar
Default ..
They are 4 ply boots my farthest distance with any boot is probably the 90 ' to the intake. I will try to get some pics when I get home. Also the turbo won't spin at a 850 rim idle. It's a brand new journal bearing 76 on3
Old 04-30-2015, 03:11 PM
Restricted User
JoeNova's Avatar
Make sure the turbo is getting oil. It's not uncommon for a rear mount to not spin at idle, especially with long tubes that size. How big is the exhaust leading to the turbine?
Also, if your boots are getting sucked in, shove the pipes into them as far as you can and reclamp. This happens a lot because when you're at part throttle, you're usually pulling vacuum.
Old 04-30-2015, 03:21 PM
ts10's Avatar
It is 3" from headers to turbo and I will try to push them in further and reclamp them.
Old 04-30-2015, 03:24 PM
ls1_chevelle's Avatar
Too small of an air filter on the turbo perhaps.
Old 04-30-2015, 03:34 PM
ts10's Avatar
Tried with and without an air filter no luck
Old 04-30-2015, 08:02 PM
11SECSS's Avatar
Sounds like the couplers are just regular rubber ones need to upgrade to a better type.
Old 04-30-2015, 08:20 PM
ts10's Avatar
I'll get a new set and give it a try. Thanks for the input
Old 05-01-2015, 04:55 AM
yenkomike's Avatar
un hook the turbo from the intercooler and see if it can suck thru the intercooler alone if not I think you need to start looking for a blockage or a rag or something. un hook both ends from the car and blow thru it with a leaf blower and see how it flows.
it should'nt suck hoses flat unless there is a large restriction.
Old 05-01-2015, 06:57 AM
Restricted User
JoeNova's Avatar
Originally Posted by ts10
It is 3" from headers to turbo.
You have massive header primaries and a large exhaust. You don't have enough exhaust velocity to spin the turbo at idle. Is that thing pretty lazy in the low-mid range as far as spool?
Old 05-01-2015, 07:25 AM
ts10's Avatar
I have not driven it yet. And I know the headers are huge they are from my previous n/a motor I figured I would try them before I go a different route. I will try the leaf blower trick when I get home. This is what it looks like underneath
Old 05-01-2015, 07:36 AM
Restricted User
JoeNova's Avatar
I would seriously consider replacing the headers with something smaller like 1 5/8" or 1 3/4" at the largest with a 2.5" collector and 2.5" piping that's either wrapped or coated back to the turbo. Spool times will pick up tremendously and you won't be giving up any top end power at all.
Quick Reply: lq4 turbo help
