f1r procharger kit
Old 05-01-2015, 05:12 PM
2000 cam'n SS's Avatar
Default f1r procharger kit
I'm looking at an F1r for a c6 that's only got 1000 miles on it but my question is what all would have to be done to run it on my 2000 Camaro?
Old 05-01-2015, 06:39 PM
BLNLS1/RX7's Avatar
What rotation is it?
Old 05-02-2015, 04:54 AM
It's a reverse rotation
Old 05-02-2015, 01:00 PM
Now he's saying its a flip drive blower f1r with normal rotation
Old 05-04-2015, 11:15 PM
Raptor_WS6's Avatar
if its for a vette then its reverse rotation
Old 05-05-2015, 06:31 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Correct, the Flip Drive does not change the rotation. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 05-05-2015, 06:57 AM
LS1Tech Sponsor
There is very little that can be used from the Corvette kit. The blower and bypass valve can be used, and if you have good fabrication skills you could use the C6 intercooler.
http://shop.brutespeed.com/ATI-3GJBB...I-3GJBB-02.htm
You would need the F Body bracket assembly
or
http://shop.brutespeed.com/Aster-Aut...er-Bracket.htm
http://shop.brutespeed.com/Aster-Mod...d-89018052.htm
or the Aster bracket and water pump, shown above
http://shop.brutespeed.com/ATI-DC017...DC017A-008.htm
ATI DC017A-008 98-02 F Body/Transplant 8 Rib Crank Pulley
http://shop.brutespeed.com/ATI-DPxxx...-ATI-DPxxx.htm
ATI DPxxx ProCharger Pulley (6 Rib and 8 Rib) w/belt option
The pulley that is on the Corvette head unit will work, but depending on the size of it, you may want a different size.
http://shop.brutespeed.com/ATI-DPxxx...TI-DB-Belt.htm
Belts
http://shop.brutespeed.com/ATI-Perfo...ATI-918853.htm
Required balancer
http://shop.brutespeed.com/ATI-3GSMM...-3GSMM-001.htm
Crank pinning kit. Not needed if you have an aftermarket crank that is keyed
http://shop.brutespeed.com/ATI-3GJAP...AB022I-002.htm
ATI 3GJAP-002/AB022I-002 00-02 Air Pump/Cruise Control Reloc
http://shop.brutespeed.com/ATI-MB008...MB008A-001.htm
ATI MB008A-001 / LS1F HORN RELOCATION BRKT-BLACK
http://shop.brutespeed.com/ATI-MF006...MF006A-024.htm
ATI MF006A-023/MF006A-024 F Body Upper/Lower Fan Shroud (2 pc)
http://shop.brutespeed.com/ATI-MF006...I-MF006I-0.htm
ATI MF006I-0 - 98-02 F Body ProCharger 16 Inch Fan
http://shop.brutespeed.com/ATI-ME001...ME001G-001.htm
ATI ME001G-001 6 oz oil pack - 3 Bottles ProCharger Oil
http://shop.brutespeed.com/ATI-3PCOL...-3PCOL-002.htm
ATI 3PCOL-002 ATI ProCharger Self Contained Drain Kit
You will need to stand up your radiator to allow room for the larger sized F-1R head unit. Depending on how you do this, you may be able to reuse your stock fan assembly. Bob
__________________
Old 05-05-2015, 06:59 AM
LS1Tech Sponsor
If you want a copy of the ProCharger installation instructions, send me an e-mail asking for them, and I'll e-mail them back to you. Bob
__________________
Old 05-05-2015, 08:02 AM
s_desantis's Avatar
The corvette and f-body ones are different, I wouldn't waste your $ and end up having to get rid of it
Old 05-08-2015, 11:47 AM
Thanks bob for your input that helps a lot. I'm actually a welder so I can make things happen. I know they are different but they say the ones for the vettes seem to work better in belt slippage. But anywho I ordered an 88mm turbo kit and decided to go that route. I don't like the strain it puts on the crank.
Old 05-08-2015, 12:26 PM
LS1Tech Sponsor
Thumbs up
You're welcome. There isn't any belt slippage with the Aster bracket, it is a very well proven design. Not a problem, you'll have a lot of fun with the added power. Bob
__________________
Quick Reply: f1r procharger kit
