5.3 Turbo Build Help Needed!!!!
Old 05-09-2015, 09:15 PM
GradE's Avatar
Smile 5.3 Turbo Build Help Needed!!!!
Hi, newbie here in desperate need of some help. This is what I have so far
5.3 vortex out of a 05 Tahoe
243 heads that have been shaved and pressure checked
Ls6 intake with 92ml throttle body
And that's about it. I want to build a mean street machine that can handle a big turbo but can run off pump gas. Something that I can drive out of town maybe 300 mile round trips. I would like to run twin turbos with an anti lag system but if that's out of the question then I'll stick to 1. My budget is currently 3500 dollars but it will soon increase by maybe a thousand. I work and pretty much can do whatever I want with my check being that I have no real bills. So someone please point me in the right direction. Oh and no I don't want to upgrade to a 6.0 I already have a 5.3 so that's what I'm sticking with.
Old 05-09-2015, 09:22 PM
GradE's Avatar
I just need someone to give me a blueprint of what I need from cam size to rocker and valve spring size. Which msd box should I use? I want to. Bore the block 30 and use dished pistons for spray. Which nitrous kit should I use? Keep in mind that I'm working with 3500 at the moment. Thanks!
Old 05-10-2015, 05:59 AM
K_Boss01's Avatar
Why bore it. The 5.3's come with dished pistons already and have a comp of around 9.6? I would just boost it to 10# on a single 76 or something. It'd give you around 5-550rwhp.
Old 05-10-2015, 09:44 AM
Red89GTA's Avatar
Also, for cam, there are several excellent sources for info here. Just of the top of my head, Martin @ Tick performance, Pat G, Cam Motion will all get you excellent results.
what car/truck is this going in? what's your hp/track # goal?
Old 05-15-2015, 04:14 PM
Gotit4cheap16's Avatar
Btr turbo cams I've heard nothing but good about. I'm going with a stage 3
Old 05-15-2015, 05:32 PM
Old Geezer's Avatar
Lightbulb There's a..
turbo section for help w/ builds such as this.
Have you tried there? Likely some folks have already BTDT, and can answer your ?'s....
Old 05-16-2015, 06:44 AM
99Brd's Avatar
EPS makes nice cams for turbo builds, give them a call they are always ready to answer an questions you may have just let them know what your running and the results your looking for. Hope this helps..
Old 05-18-2015, 12:18 PM
cr250r's Avatar
i'd do a single 80mm BW stage 2 turbo cam from tick if you want pump sell your 243's for 317 heads and you can run 20 psi of boost on 91
Old 05-18-2015, 12:48 PM
KCS
Moderator
KCS's Avatar
I agree.
Old 05-22-2015, 03:14 AM
GradE's Avatar
Thanks everyone!!! I purchased a turbo kit from JS racing a few days ago. It should arrive shortly. I'll keep you guys posted with pics and vids as soon as the build gets underway.
Quick Reply: 5.3 Turbo Build Help Needed!!!!
