ctsv supercharger bypass valve swap
Old 05-15-2015, 09:20 AM
ToxicWS6's Avatar
Default ctsv supercharger bypass valve swap
so im putting a ctsv supercharger with zl1 ld on an lq4 with an 03 truck ecu (going on an 03 silvy) i got everything figured out except the bypass valve, i get the basics of how it works, vacuum pulls it open, boost pushes it open when needed/TB closes, but obviously i dont have the plug for the solenoid on my harness and not an option in tuning on my OS. how would i run this in a "manual mode"? it looks like i may be able to put a manual boost controller in its place and if so possibly adjust from pulley boost level or lower if so, but if anyone has insight on how to run this on a swapped vehicle id greatly appreciate it!!
Old 05-18-2015, 10:07 AM
Pocket's Avatar
Yeah, take it off
Leave the lower port on the BPV open to atmo. The port on the #2 runner can be plugged or run to a boost gauge
Boost controller is your right foot
Old 05-18-2015, 10:34 AM
ToxicWS6's Avatar
ok cool, i didnt think it was like a BOV on a turbo set up since the TB is before any boost/pressure happens
thanks! btw thats my favorite kind of boost controller
Quick Reply: ctsv supercharger bypass valve swap
