Benefit from a bigger TB?
Old 05-16-2015, 02:13 PM
MonmouthCtyLS7's Avatar
Default Benefit from a bigger TB?
Changed up the turbo build a bit and will be running a 90mm LS2 intake. I have a 85mm TB now would I see any benefit upgrading to the 90/92 mm TB. Setup in sig.
Old 05-16-2015, 03:32 PM
turboventura's Avatar
What size is your charge pipe? I wouldn't think having a TB that's bigger/flows more than your charge pipe would be beneficial, but I'm no geologist.
Old 05-17-2015, 02:49 AM
DER E30's Avatar
Isn't it not worth that many whp in an NA application? I should think it would be worth less with a hair dryer forcing air through it... Sure, on a max effort motor every little bit counts and more air is more air, but the $ vs whp ratio isn't good... I'm no expert though.
Old 05-17-2015, 01:24 PM
rotary1307cc's Avatar
Its worth more to slow the air down entering the plenum more than anything
Quick Reply: Benefit from a bigger TB?
