Ams-500 controller ramp rate function
To users of the ams 500 boost controller, does your ramp rate function work as commanded?
Example. If you dial 3 psi per second, does your boost respond as such? Does it show up in your logs?
Mine does not seem to work. 10-11 psi on gates, stage 2 is set to give me 20 on my latest runs. It gets to boost a lot faster than ramp commanded. There should be 3 seconds of delay at 3 psi per second to reach target but my logs basically show less than that. I gotta check the actuals but it appears to be less than 1.5 sec. I seem to see no difference in 3 or 7 psi per second ramp rates that i just tried at the track.
Just curious if others see similar things
