Truck fpr and boost
Old 06-06-2015, 05:44 PM
jprince's Avatar
Default Truck fpr and boost
Hi with a returned fuel system and the truck fpr with boost would this damage it .. ? Wondering based on boost was not in the original plan of the engineers? Or would it work as a rrfpr?
Old 06-06-2015, 07:42 PM
yenkomike's Avatar
works perfectly. I run a single bosch 044 pump and I use the stock regulator. I turned it down to 50 psi base. and run 80# injectors. no issue at all.
Old 06-06-2015, 08:40 PM
69-chvl's Avatar
Does it increase pressure with boost?
Old 06-07-2015, 05:57 AM
jprince's Avatar
Is the stock regulator adjustable ?
Old 06-07-2015, 08:10 AM
yenkomike's Avatar
the stock reg. is adjustable if you turn the little tamper proof torx in the center of the diaphragm. it is touchy mine was 58 and I turned it to 50.
as far as boost reference I have never watched it but it does reduce pressure with vacuum so I whould assume it adds with boost being a diaphragm style but I have never witnessed it rise.
Old 06-07-2015, 10:12 AM
Forcefed86's Avatar
Factory is not a rising rate regulator. It will not rise 1:1 with boost. So if your base if 50 and u run 20lbs of boost your fuel pressure drops to 30. Anything less than 42-43psi and your spray pattern is crap and your injectors flow less than they are rated at.
Old 06-07-2015, 11:13 AM
yenkomike's Avatar
have not noticed that but im at 10# boost. I will check mine with a guage and some air pressure and see if it rises at all. I know it lowers with the engine idling. and I set it up this way as seen on some of denmah's builds. i'll post back with my results.
Old 06-07-2015, 11:28 AM
jprince's Avatar
Great thanks love to know what it does under boost
Old 06-07-2015, 02:46 PM
Forcefed86's Avatar
Wasnt' a vac port/barb on the FPR on the truck intake I have? It's one of the newer intakes though. I thought these were dead headed and had the FPR in the tank on the 06+ Ls setups?
Old 06-07-2015, 02:56 PM
yenkomike's Avatar
yes the newer intakes have no boost/vac reference and no return line(deadhead) but the 03 ones have a return line and a vac line from the intake to the reg.
both of my 05 engines had the single fuel line and no return or adjustment screw.so I swapped to the older intake with no egr and return fuel line setup.
Old 06-07-2015, 04:52 PM
GMCtrk's Avatar
The stock truck regulator is pressure referenced, 99-03 model years.
04 up is returnless system with regulator in the fuel tank.
Old 06-07-2015, 04:57 PM
ls1_chevelle's Avatar
read above this post... /\ /\
Quick Reply: Truck fpr and boost
