4 inch exhaust
Old 06-10-2015, 06:02 PM
3 window's Avatar
Default 4 inch exhaust
Plan on running a single 4" exhaust on my turbo Nova. I'm looking for a muffler that is fairly quiet and also has NO drone. Let me know what you guys are using. The car will be driven on the street, I'd like it to not rattle my brains out. Thanks in advance.
Old 06-11-2015, 01:45 AM
krazy4's Avatar
I'm a huge fan of Magnaflow mufflers for street cars.
Old 06-11-2015, 06:18 AM
Restricted User
JoeNova's Avatar
I'm a huge fan of cutouts. Open exhaust power, stock exhaust quiet.
Old 06-11-2015, 09:19 AM
slow trap's Avatar
i run a round case and around 24" long chinese knockoff of the magnaflow muffler. straight through design with packing and is pretty quiet for a straight through 4" and loses very little if any power. i tried my 4" cutout and made the same power.
Old 06-11-2015, 09:24 AM
3 window's Avatar
Any drone when cruising?
Old 06-11-2015, 09:28 AM
slow trap's Avatar
at a couple spots but i think it is mainly my y pipe causing that. not drone just alittle rasp. very clean sound. i think they are only around 50-60 bucks so they are definitely worth a try.
Old 06-11-2015, 09:39 AM
Reject's Avatar
think the drone is what kills the fun honestly
Old 06-11-2015, 09:45 AM
aggie91's Avatar
I have heard of people using a muffler designed for diesel pickups on their turbo cars.
Old 06-11-2015, 03:32 PM
thunderwagen's Avatar
I ran a 4" magnaflow diesel muffler on mine at one point and it was super quiet and had no drone at all. 3.5 down pipe going into a 4" magnaflow cat back for a duramax I cut up and made fit.
Old 06-12-2015, 06:18 AM
forcd ind's Avatar
I run 2 mufflers, one is a straight thru oval b4 the rear, and another straight thru round after the rear-I wil have to look up the makes, but no drone, and I can hear the stereo, lol
Old 06-12-2015, 08:23 AM
Moderator
denmah's Avatar
if its front exhaust, building another entire swappable pipe on is a decent option haha, other than that i think a super quiet exhaust and remove the muffler for racing or dont bother, it will kill power and not be quiet enough not flow enough etc etc
i actually am going to make a bolt in insert on my white car 4 inch exhaust and have it knock the exhaust outlet down to like 1 inch just to really quiet it down and see how that works out, obviosly ill pull the bolts and cover/insert when i race
Old 06-12-2015, 02:38 PM
willizm's Avatar
I have a 4" downpipe that goes into a cutout and then tapers down to the 3" magnaflow catback
Old 06-12-2015, 03:00 PM
6669camaro's Avatar
Here's what I did. 4" down pipe with a homemade dump welded in then a home made 2.5" y pipe into some chambered mufflers. Nice and quite with the exhausted capped and all the power with the dump open. Way cheaper then a $300 cut out and takes like 20sec to open up.
V band dump
Old 06-12-2015, 03:06 PM
Forcefed86's Avatar
The Hooker Maxflow was one of the quietest best flowing mufflers on a test done a few years back.
I'm a fan of the 4" dump with a 2" kick out to a stock muffler OEM muffler.
Old 06-12-2015, 03:08 PM
stoverz28's Avatar
Space is going to be a big factor as most 4" mufflers are made for trucks. A cutout with 3" pipe behind that will be much easier to fit and have a lot more muffler options.
Old 06-15-2015, 03:20 PM
Orr89rocz's Avatar
Dynomax ultraflo round case.
Diesel mufflers also work but usually alot longer length
I run a 5" by 30" mbrp diesel muffler on my car and it sounds awesome and no drone
Old 06-15-2015, 07:05 PM
3 window's Avatar
Looks like I'm gonna end up with the Maxflow. Seems that it'll fit where I want it. Thanks everybody. Plus, I might be able to sneak another bullet type muffler under the car as well.
Old 06-16-2015, 12:17 AM
7 Second Club
GotBoostRacing's Avatar
One last piece of info for you. I ran the 4" Magnaflow race series with a GT4788, pretty aggresive cam, and it was 88db making a pass at the track. We had to pass 90db sound to race past 10pm, so that's why it was checked. No drone.
Quick Reply: 4 inch exhaust
