Cleaning the Intercooler?
I dont know if the intercooler has been clean, I guess it is possible for the tiny fins to get clogged up with dirt and bugs. Is it possible to just use some A/C cleaner for it to be more effective? Suggestions?
Could I gain possibly more boost from doing this?
Dont use a power washer though as you will easily damage the fins.
If you wanted to remove the cores, you could let them soak in some soapy water first which would help dislodge any dirt/bugs prior to blowing from the rear. Obviously dont let any dirt get inside the unit
There should be a write up of hidden horsepower on these procharged vehicles. The previous owner must not have took care of it this way.
So you could imagine the air it is sucking in and particles picking up from the road. The fins get clogged and not efficent as before. Now much more colder air running into the intake.
