What cam with a PT7675
I'm curious what cam you guys are running that are using the PT7675 turbo? I'm leaning towards the Tick stage 1. I have a stock bottom end 5.7 with 317 heads, PT7675 .96 AR, M6 with an S60. Waiting on my Huron front mount kit to get delivered. Car is just going to be a street toy, no track time. Thanks.
I kind of want it to have a little chop to it, but I think I would rather have it build boost sooner over the chop. You can hear some chop with both the Tick stage 1 and 2 turbo cams from the vids I have watched.
i run the tick stage 1 cam in my stock bottom end ls1 with 317 heads. im running the on3 76mm turbo tho. spool is fast and cam is very street friendly. cam has a little chop to it. im happy with it. but it is nothing compared to my buddies tsunami cam lol
I ran a TU1 cam with my PT7675 and found that setup to be really fun. Super responsive and just a fun car to drive on the street. Spooled quickly and idled great. Very streetable combination.
Shannon Taylor made 780 to the tire with a 7675 and my stage 2 with a 5.3 on 17 psi iirc...
Ryan Munson made 775 on 14 psi ( manual transmission) with a 7675 and a stage 2...
Those are the 2 examples right off the top of my head I have to offer with one of my cams and that turbo.
Off wastegate I'm at 16-17lbs, which is plenty fun. Have the boost controller for more if its needed.
With my PT7675 on an L92 headed 6.0, I ran a 220/220 114+0 XER cam and a 224/230 114+6 XER cam and couldn't really tell any difference in power or spool up, both ran great. It made 540whp just under 8psi non-intercooled and 620whp at 10psi intercooled on a dj248 with the 224/230 cam.
