1987 Camaro Z28 Turbo 5.3L 4L80e
Well i decided I would toss my build up on here seeing all the 3rd gen builds popping up. Maybe it will help others on theirs. I also didnt want to drag on a full build on here, wanted to wait til it was somewhat complete.
I bought a low mile stock LG4 305 auto car 2 summers ago after getting bored with my FRC vette. I wanted to build another 3rd gen (last being a 370 LS single T6 turbo) but wanted it more street friendly with a goal of around 550whp, so it made sense to do a 5.3L build this time around.
The first summer I had the car I worked on suspension, then built a 3.5" exhaust all the way back since I knew I was going turbo.
Engine
SBE 2005 5.3L (L59 motor)
2004 LS6 cam
China Headstuds (stock head gaskets)
BTR .660 springs
LS1 intake
Ported truck Throttle body
Melling High pressure oil pump
ATI Balancer
Corvette accessories
Fuel
80# Siemens injectors
Summit AFPR
-8an Feed
-6an Return
Holley Fuel Rails
Walbro 450 pump
Turbo setup
Flipped Truck manifolds (vbanded)
2.25" 14awg mild crossover
Twin 38mm Tial MVS Gates
GT45 turbo (for now)
Ebay 4" Intercooler
Jodar 50mm BOV
Drivetrain/Brakes
1997 4l80 fresh reuild
TCI Flexplate
P.I. Vigilante Triple disk converter
Stock 1998 3.23 torsen rear (purchasing a 9" soon)
1999 SS ZR1's all around (waiting to buy Street lites soon 15/17 combo)
C5 Z06 Fronts with GMMP Slotted/drilled rotors
LT1 rears
Suspension
Ground Control weight jacks (800/175lbs)
Koni Yellow all four corners
Custom torque arm (made myself)
Custom Panhard Relocation (made myself)
UMI rear LCA
UMI Panhard adjustable
Gauges
Speedhut Revolution gauges
innovate SCG-1 (boost controller/AFR/Boost gauge
Maxidisplay center gauge (custom taylored to my specs from Hakan @ Maxigauge) I wanted to do a racepak but in the end this was a bit cheaper
Engine
2004 LS6 cam
BTR .660 springs
LS1 intake
ATI Balancer
Fuel
Summit AFPR
-8an Feed
-6an Return
Holley Fuel Rails
Walbro 450 pump
Turbo setup
Ebay 4" Intercooler
Jodar 50mm BOV
Drivetrain/Brakes
TCI Flexplate
LT1 rears
Suspension
UMI rear LCA
Gauges
So far the car is out on 6psi and seems to be running great. Usually its steady 170* temps, 50psi hot idle oil pressure etc. I have surprised a few people for a stock motor on 6psi how good it moves.
It shocked a few people at the last local car show I went to. Lots of older guys pretty interested in the setup.
Jay
Jay
Ya been over here for a long time, just didnt wanna bore people with the entire slow build. Actually came along quicker than I thought with a newborn lol. Ghost town is right! At least I can use this thread for problems/issues and possibly get a reply! lol
Jay
Jay
I havnt added it up but i would say around $7,000 for everything (trans, converter, motor, turbo stuff, fuel etc)
Jay
I bought the turbo from DNS on ebay. Most common on theturboforums. I built the entire setup myself. The wastegates, bov and injectors i waited for black friday and got a smoking deal on them.
Pretty well the entire build I waited for deals to pop up when i was driving the car with the gutlass 305. Being my 4th time buying LS parts I knew where to shop lol.
Jay
Jay
The Dash I built myself. The Maxigauge (center display) uses an external box much like dakota digital. So I ran an seperate sensor harness for that, then I was left with the Tach, fuel pressure, volts and fuel level. (fuel level, signals and highbeams I tapped into the stock cluster harness)
The Speedo is a GPS unit which makes life easier.
Jay
What would I need to do a similar build on my 91 rs and keep ac? Is it possible? I'm very new to this so I apologize for all the questions. I'm learning a lot here though and really appreciate the input.
