What Harmonic Balancer Are Turbo Guys Using for Oil Drain in Timing Cover
Like the title says I am having a problem with my clearance for my -10an turbo drain on the front of my timing cover. Right now I am using a powerbond sfi race balancer and for the fittings I have a -10an weld bung and a 45 degree bend. I cannot find a way to fit it on with enough clearance for the belt balancer and water pump. Do I need to go with an Under Drive Pulley? Or should I get an ATI damper without the AC pulley? What are you guys using and what fittings combination do you have
The following users liked this post:
Homer_Simpson (09-08-2023)
I used an ATI Vette balancer (stock size) and didnt install the AC pulley. However I was dumb and drilled one of the 4 little flat bosses on mine, found out after thats where the oil pump bolts are. So I had to use a button head cap screw in that location for better flow. Its pretty tight but the belt doesnt rub or nothing.
Jay
Jay
Jay
Jay
I put my -10 drain in the same spot and used a button head on the oil pump as well. Later I did pulled the pan and welded a fitting on it.
