My Turbo LSX Z31 Build.
Old 06-02-2016, 09:23 PM
  #81
Nismo Kid's Avatar
Next I installed my timing & rear main seal covers using some Alignit tools. These things come in handy. After the covers were aligned I installed the seals.
Moving on I installed the Improved Racing oil pan baffle into my F-Body oil pan. It's a shame that something so nice won't be seen.
I also deleted my oil level sensor but using Dorman Drain Plug 65221.
The balancer started looking lonely on my work bench so I slapped it on followed by the ARP Balancer Bolt.
  #82
Nismo Kid's Avatar
Installed the F-Body windage tray & pick up tube. Rotated the engine a few more times to check for clearance. Then tossed the oil pan on.
Old 06-02-2016, 09:24 PM
  #83
Nismo Kid's Avatar
  #84
Nismo Kid's Avatar
To finish up the 4.8 I installed the water pump & valley cover.
With the 4.8 together I needed to find a clutch. I originally ordered clutch but they requested I buy their flywheel. Which informed that would be useless for me. Well that struck a cord with them. So I explained my setup & they told me the LS wouldn't even fit in car. I told them to Google my car which must be mystical unicorn ROFL. Got my refund and began searching for another option. Found a couple options. In 1 hand there was an affordable 700-800$ clutch. In the other there was a 2100$ clutch that was way more than I needed. The 1st clutch appeared to fit my needs & had a nice price to match. So I gave the clutch maker a call. They informed me that my set up would be pushing to the limits of that clutch. They've had people make 800+hp but on less torque producing V6's. Not wanting to be held back by my clutch I went with option 2. It hurt in the beginning. Hell this clutch cost more than my car, turbo, engine & transmission combined lol. But it'll aid me obtain my goals & pay for itself in the long run. Due to the fact it's a twin disc & can be rebuilt. I went with Ceramic & Rigid Organic disc combination per Clutch Masters recommendation. The clutch comes with a custom flywheel that allows you to back the LSX with a Z32 transmission. With that said they're made to order. I was quoted 3-4 weeks for them to make it. I figured it was likely another week for shipping. Boy was I wrong. My clutch was delivered in just 10 days!
While I was waiting on my clutch I went ahead & had my starter rebuilt.
I also converted my power steering rack to manual. Here's how the rack started out.
After I hit it with some glass bead media
  #85
Nismo Kid's Avatar
Disassembly began
Old 06-02-2016, 09:25 PM
  #86
Nismo Kid's Avatar
Removal of the high pressure seal & inner tube seal
  #87
Nismo Kid's Avatar
Cleaned everything up
Old 06-02-2016, 09:26 PM
  #88
Nismo Kid's Avatar
  #89
Nismo Kid's Avatar
Old 06-02-2016, 09:27 PM
  #90
Nismo Kid's Avatar
Let the assembly begin!
  #91
Nismo Kid's Avatar
  #92
Nismo Kid's Avatar
Old 06-02-2016, 09:28 PM
  #93
Nismo Kid's Avatar
After it was all assembled I gave it a fresh coat of paint for protection.
  #94
Nismo Kid's Avatar
I ordered some grease fittings for the finishing touch. But I'm still waiting on them to arrive. That way I could grease my steering rack during routine maintenance. I'll add some pics in my next update.
Sold vs Factory rubber bushing
Installed manual rack with new sold bushing.
  #95
Nismo Kid's Avatar
Here's my new clutch & flywheel in all their glory.
Old 06-02-2016, 09:29 PM
  #96
Nismo Kid's Avatar
The standard length LSX flywheel bolts were just a tad to short. So I ordered some extended length ARP bolts #244-2902.
Now I installed the flywheel & clutch onto the 4.8.
Decided to clean the transmission up a bit.
  #97
Nismo Kid's Avatar
Installed the clutch fork dust boot, chromoly pivot ball, 350z clutch fork, throw out bearing & sleeve
  #98
Nismo Kid's Avatar
Then I mounted my transmission to my engine.
I finally installed my engine & transmission back into my Z!
Old 06-02-2016, 09:30 PM
  #99
Nismo Kid's Avatar
It's beginning to resemble a car again. Lol
I told myself I wouldn't install the kit until I got it Ceramic coated but I couldn't take it anymore.
  #100
Nismo Kid's Avatar
Quick Reply: My Turbo LSX Z31 Build.
