I am having twins
#83
#84
#88
#89
Way to go
Tickled to find your build--awesome! I am gathering parts for the same setup
or have been for a while and this is just what I needed. Where is your turbo oil supply source--looks to be coming from front and did you find some pre built stubs for the wastegates or fab the whole thing. Especially liked the fact you have just tested the fuel pumps I was scared to chance.Thanks a million.
#90
I fabbed all the other plumbing.
Glad to help
#91
T.Fiddler, what RPM are your turbos fully spooled at? I have what I think are the same/similar turbos on my 5.3. I feel like they are not spooling as fast as they should be. The internal gates keep the boost down at about 10 lbs which is odd because yours wouldn't keep your boost down at all.
#92
But I am only floored for about 1.5 seconds as the tree comes down.
I am still learning the car as I only have 9 runs on this combo. I will post a data screen shot in a bit.
#93
I am sure if I left at a higher rpm on the 2 step this graph would look a bit different. But like I say I am still learning the combo. My converter is VERY loose now so that will be adjusted this winter.
5.93 data by Tom Fiddler, on Flickr
#95
#97
Depending on your HP goals I would use these or 60mm. I am sure my engine will get to 5.7 when it needs freshened. I am happy with this setup, but max power was not my goal.
