Twin on3 76mm vs Percision 62/62
Restricted User
Yet another L33 making insane power. Im not 100% convinced the precisions will make you faster. Down low power is great, but only if RPM drops enough when you shift to put you in a spot where the precisions shine over the 76s.
They will help a lot. It's all about the 60 foot and the 330. The car had a 6.0 in it before the 5.3 I lost 225hp and 250qt on the hit just cause of cubic inch. The 62/62 with the .58 ar's is the key will play the cubic inch roll ha ha Ha
It's the TQ that's going to kill it. I had a set of 6265s on a 5.3, stabbed the throttle at 2900 rpm and by 3200 rpm it made 876 ft lbs of tq on 12 psi. They are going to light off FAST!
