Washer Fluid Low Level Warning Light on 00 TA?
^This. That coolant level sensor is usually useless anyways. take it and put it into your reservoir and extend the plug to it. You get a nice red light on the dash when it gets below the sensor level
I got the exact same sensor for my setup. Be aware though, in the pictures its actually upside down. So the light will stay off as the "bobber" floats up. As soon as the fluid level is below the sensor the light goes on. I only say this as I put it in the middle of my tank thinking the sensor falls towards the bottom the light came on. So you put the sensor near the bottom. On a good note I know really early when i'm low on meth.
Cool and thanks for the PM. I think I'm going to pick one of those up especially since I have a devils own kit and can tie it into the controller and my low coolant light (controller is in the glovebox so I most likely won't see the light)
Just noticed the crazy expensive shipping for this part though. Geez. Any other company make a switch like this?
