Ethanol injection????
This may seem like a stupid question, but why doesn't anyone use Ethanol instead of Methanol for cooling down the intake charge or to prevent detonation on a ump gas setup? Is it easier to ignite and therefore dangerous? It seem to be more readily available at least as E98 by the drum and I do not believe it is as corrosive as Methanol correct?
Restricted User
Some do...they just run it as E85 in the main tank and inject via their injectors lol
Or I'm sure you could just run E98 in your main tank provided the system is designed around that fuel.
Spray e85 out of a alky nozzle pre compressor w a 200psi pump.
And it works extremely well. Don't know if the pump will hold up to it. But its been on there since January. It's just a Bolt ons lightning. But it did pick up like 40rw w a tune. System is same as a meth injection kit. But the guy wanted to use e85. He is around corner from a e85 pump station.
Seems to be working fine.
I'm gonna run something similar on my car. W e85 instead of meth/water
The standard meth inj pumps aren't designed for petrol based fuel of any kind. So you can't put e85 or E98 in the tank if it has any "gas" in it. It will eat the pump diaphragm. Pure ethanol would be fine. The guys overseas that can't get meth use cheap 80 proof vodka which is basically ethanol.
