eBay Oil Cooler Kit
eBay Oil Cooler Kit
Hola fellas, has anybody ran or had any experience with the eBay Engine Oil Cooler kits? I'm looking at one now for my turbocharged 02 SS to help control oil temps. Thoughts?
http://www.ebay.com/itm/30-ROW-AN-10AN-UNIVERSAL-ENGINE-TRANSMISSION-OIL-COOLER-FILTER-ADAPTER-KIT-/252026708417?hash=item3aadf661c1&vxp=mtr
Excellent! I have a little fan off a retro fit AC system that will work good. Did you guys see any benefits to running the cooler w/ fan? Better pressure, cooler temps? Do you have any picks of how you mounted it? I was thinking under the passenger side where the exhaust used to run.
engine oil cooler
I used this one and I was impressed by how nice it actually was,i have no temp gauge but my engine is not going over 205 anymore. and before it was hitting 220
http://www.ebay.com/itm/25-Row-Engine-Oil-Cooler-Kit-Sandwich-Plate-For-BILLET-LS1-LS2-LS3-LSX-VE-HSV-/191584985323?hash=item2c9b5ae0eb&vxp=mtr
25 Row Engine Oil Cooler Kit Sandwich Plate for Billet LS1 LS2 LS3 LSX ve HSV | eBay
EBay oil cooler
I’ve got one on my Lsa the first one was **** as in it either came with the massive hole in fins or oil pressure blew it out, was a 30 row an 10 fittings with fan set up , so bought a better brand one same every thing and yeah car runs so much cooler helps heaps especially with my blower mods
30 ROW AN-10AN UNIVERSAL ENGINE TRANSMISSION OIL COOLER + FILTER ADAPTER KIT
Did you end up using this cooler? I think I am going to use one for my transmission @The ******
Never leaked and would increase oil pressure after a few hits so I know it was cooling the oil.
Was on the car and working when I sold it so about three years.
You may want to find one with -06AN fittings though, the trans usually runs at much higher pressures (150-200psi) so a large -08AN line isn't needed.
I'm using a trans cooler w/ fan at the back of my car currently with -06AN lines and it works really well.
Fit as big a cooler as possible for the transmission, you can't over cool the trans. ; )
The following users liked this post:
02redchevy (02-21-2023)
Yes sir I did, I ran a small fan on it and it worked very well.
