Stranded with bad map with sd tuned 99 ls1
My map came undone just a little and let me stranded and i wanted able to get it fixed there so i had to get the car triple a'd . No biggie as i have the plus package but my question is this .
Any way to have a map go bad or unplugged and be sd tuned and not get stranded ?
Last year my map did go bad and the car just idles and takes not throttle input .
I thought dodges were mafless tunes , how do they get around it if the map goes bad and get ls1 pcm be made to not get stranded with a bad map if your sd tuned ??
You are talking about getting speed density tuned so I am thinking you mean the Mass Air Flow sensor gave you the issue and not the Manifold Air Pressure sensor? If it was just the MAF there are a lot of tuners out there who tune SD and a lot that actually prefer it with a forced inducted car. If you are actually talking about the MAP sensor, I do not believe you can tune your car without that especially supercharged.
i already am sd tuned and have been for 2 or 3 years . The map sensor went bad last year and i was stranded , the car would just idle , any revs and it stalls or wants to stall .
Without having anything to measure the air for the car I wouldn't think there is a way to run the vehicle without the MAP if the car was strictly SD tuned.
What sensor are you getting that is failing? I had a DPE 2.5 that I would have issues with. Got it from a buddy who bought it for boost plans for his C6Z and it would randomly flat line. Now we know why he got a good deal on the used sensor. Took a good day of chasing around and swapping in the old map sensor before I realized it was junk.
last year i had a map fail this year it just became unclipped or unplugged . But was just curious if it would run and drive if it went bad . And how the other brands do it , or how did gm do it in the last 3rd gens that were sd tuned.
MAP is required for the SD tuning, you take that out of the equation and you are shooting in the dark. All of them use a MAP or MAF sensor of some sort to measure the airflow to determine fueling.
