turbo motor runs great until vacuum lines are hooked up
Old 09-13-2015, 09:04 PM
Dimeomboost's Avatar
Default turbo motor runs great until vacuum lines are hooked up
My 5.3 is finally done new turbo finally mounted and it starts great runs great idles good but when I start hooking up vacuum lines it starts to big be sluggish and runs rough unless I unhoom the charge pipe it gets a little better but not much it has a start up tune but not a dunk tune yet will this solve my issues or do I need to figure this out before hand it's a speed density setup with both front o2 sensors hooked up I just want to be where I need to be before loading up and heading to the dyno it's a fuel injected stock pcm motor no mass air meter
Old 09-14-2015, 05:40 AM
Restricted User
JoeNova's Avatar
Which vacuum lines are you hooking up?
Old 09-14-2015, 06:17 AM
forcd ind's Avatar
Prob needs tuning once all the sensors are hooked up, MAP is prob throwing it off
Old 09-14-2015, 12:33 PM
coltboostin's Avatar
Give it an air bleed until you get it tuned- will help your idle and tip in.
Old 09-14-2015, 06:01 PM
The BallSS's Avatar
I had to adjust the throttle body opening when I first started mine to get the IAC counts where they needed to be, it needs to be between 30-60 counts on your hand held. Mine wouldn't idle either but after that it was much better.
Quick Reply: turbo motor runs great until vacuum lines are hooked up
