Check Valve For PCV?
2 questions.
-Can I run one?
-Which one is recommended
For a turbo 6.0. I currently have 2 -10an hoses (one on each valve cover) running to a breather tank with an open element filter.
I was thinking of putting a check valve in between the passenger valve cover port and the fitting behind the throttle body to pull from while in vacuum. Is this ok to do?
-Can I run one?
