Too many mile for an A&A??
Old 10-10-2015, 06:57 PM
GoFastKid's Avatar
Default Too many mile for an A&A??
Recently picked up a 2000 M6 C5. It's been well taken care of and serviced. Clock reads 124k miles. Other than some long tubes and cold air, it's bone stock. I was considering a A&A kit and running a mild 7-8lbs with a good tune. I have a goal of 500-520rwh. What are some other areas I should address during the swap? Valvetrain wise like springs, lifters, pushrods etc. I'm a noob to FI and any suggestions and help is much appreciated.
Old 10-10-2015, 07:13 PM
lowslung85's Avatar
That won't be a problem at all with those miles, some good dual springs hardened pushrods and trunion upgrade is always a great idea, I have an a&a setup on my 99 c5 with a ysi it makes 950 josh at a&a is awesome they have the best customer support I have ever dealt with.
Old 10-10-2015, 08:02 PM
senicalj4579's Avatar
Do you plan on keeping the car if the motor goes? If you are then I'm thinking just get the supercharger and run low boost see how long you can get out of it. Then when it goes you can put a better motor in and you will already have the sc for it.
Old 10-10-2015, 08:10 PM
GoFastKid's Avatar
Yeah, the car isn't going anywhere. I think I will pull the trigger on this set up and run it on low boost.
Old 10-11-2015, 12:22 AM
Detoxx03's Avatar
I'd do it.
Old 10-11-2015, 07:34 AM
JRENIGAR's Avatar
I put a Vortech kit on my last f-body with 172k on it. Sold when it had 242 and still ran great. Completely stock engine trans and rear. Ran 8-9#'s on 93 only.
Old 10-11-2015, 02:54 PM
GoFastKid's Avatar
Is it necessary to upgrade the valvetrane?
Old 10-12-2015, 10:29 AM
DavidBoren's Avatar
Define "necessary"...
Absolutely vital/crucial to the success of adding a centrifugal blower? No.
A really freaking good idea for any time you want more power or performance than the original equipment? Hell yes.
Boost usually requires heavy duty valve springs. That's all that is really necessary. But heavy duty valve springs should be paired with heavy duty pushrods. And the trunion upgrade is a durability thing, it is a good idea to do regardless of boost.
Old 10-12-2015, 03:24 PM
LS1Tech Sponsor
Slowhawk's Avatar
No problem with the mileage. For safety I would replace the valve springs. You can even put in new stock springs if you like.
Quick Reply: Too many mile for an A&A??
