Seeking recommendations for rearmount camshaft
Hi guys,
Slowly piecing together a rearmount turbo setup (looking to do most the work myself) but also planning an engine swap before the resrmount gets installed.
wandering if anyone can recomment a cam ? i have looked into comps "remote mount grinds" a little but would like to know what others have used / recommend.
Motor is an LS2 running L98 heads / L98 inlet manifold.
I currently have 4-1 pacemaker headers but will consider swapping them out for cast manifolds to help with spool time if needed
Still deciding on the turbo - possibly GT45 or maybe T76.
Not sure if the remote mount would prefer big split, small split, reverse split. i was originally going to use my isky 220/230/113 (in my current motor), but now that im building this LS2 i can pick and choose what ever cam i wish !! (not chasing huge HP, looking around 8psi of boost - good street manners, AUTO wuth 2100 lockup convertor 3.46 gears but may drop down to 3.07)
Thanks for the help
Dan
Thanks for the help
Dan
