S475 92 to 83 turbine size
im a little confused. you are say you want to go from 92 to 83 (T4).... the turbine itself isnt t4 or t6.. what is your current turbine house? are you going from t6 to t4?
if you are asking what i think you are asking yes i do believe the dp flange is the size
maybe you need to look elsewhere in the combination if you have spooling issues with a 92mm turbine S475.
People can have that unit making 10 psi before 3k rpm with 5.3's when its done right.
