Turbo suggestion for twins
Old 10-23-2015, 07:46 PM
vht
vht's Avatar
Default Turbo suggestion for twins
Bought a 06, 6.0 out of a truck and need some advice. I'm replacing the usual, head gaskets, studs, cam, lifters and springs. This will be a street and strip deal. I have tons of hood, and side clearance. Not a whole lot in the front. I really want to run twins. On page 27 of Denmah's most common bought items is the set up I'd like. VS racing forward facing headers, some real nice 90's to mount the turbos which I need to find out where they came from. What turbos would work good and hold up without breaking the bank? This is budget, so I'd like to find something on ebay, VS or CX racing I figure would have something.
Old 10-24-2015, 06:42 PM
cr250r's Avatar
Borg s362 or s366 turbos will suffice 1000+ still spool good 6-750$ a piece
Old 10-24-2015, 07:44 PM
coltboostin's Avatar
Any china 61-70mm in twins fill fit your goals
Old 10-24-2015, 09:46 PM
Almost_There_1's Avatar
I have some brand new cx racing elbows in not gonna use and I need to get rid of. As for turbos, a pair of 366s would be badass. Or you can go on3 if you're on a budget.
Old 10-24-2015, 10:43 PM
vht
vht's Avatar
Would be better of with T4's wouldn't I? Need something budget right now, what would you suggest in maybe CX racing's turbos, or something that somebodys had experience with.
Old 10-25-2015, 01:24 AM
vht
vht's Avatar
Found the 70mm On3 for $299.
Old 10-25-2015, 08:46 AM
stangeater01's Avatar
Where you found that hell twin 70s on should good for 850 + I'd think
Old 10-25-2015, 11:05 AM
Good price. The best I was able to find was $317 a piece a few months back.
Edit: wicked69 had good luck with the 70s. Went 5.9X in the 1/8th. 3800lb rw.
Old 10-25-2015, 06:10 PM
vht
vht's Avatar
That's moving for that wt. Mine should weigh around 31 to 3200. What size WG's should I run with them, 2 44's?
Old 10-25-2015, 07:09 PM
greenturtle05's Avatar
what A/R are you going with?
Old 10-26-2015, 09:43 AM
Forcefed86's Avatar
How much boost power do you want to make? Pair of 38mm gates should be plenty if your placement is done correctly.
Personally if I were buying china cheapies I’d jump right into the 76/65 units with .68 t4 housings. Same price as the 70mm and move a little more air. A S366 will move more air than the cheap china 76’s. Wicked69 ran out of steam faster than I would have though with the 70’s.
http://www.ebay.com/itm/251453904780?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 10-26-2015, 11:32 AM
How much power do you plan to make? As for wastegates, I went with the On3 44mm units. I almost went with the eBay tial knockoff but read too many horror stories them not opening, over boosting, and popping the motor. I was able to get 2 turbos, 2 wastegates, and 2 bovs for about $1100 shipped. I eventually plan to upgrade to s366 and with either Tial or JGS gates and bovs, but the ON3 stuff should work on the mean time.
Old 10-26-2015, 07:01 PM
vht
vht's Avatar
I want to run some high to mid 9's at some point. I'll update as I can, this will be my first LS and turbo. Plus it's going on an unusual set up. Plus you always want to go faster. I just want to make some more passes again. It'sn got to be on a budget right now, the doctors have taken enough this year to buy several turbos. I'm going to have to depend on you all to guide me.
Old 10-27-2015, 09:46 AM
Forcefed86's Avatar
Depends what you want to spend.
For a basic 6.0 LS S366’s are the best quality turbo for a twin setup IMO. You can get them for about $550 shipped each. (look on Ebay)
The china 76/65’s above for china turbos at $300 each. The china units are also smaller than the S366’s and might be easier to package. Either are capable of 1000+whp. Reliability on china stuff is hit and miss. A lot of failures I’ve seen reported are user error and would have taken out any turbo... China made or otherwise.
With a little common sense and preventative maintenance, I’ve never had a problem with a china gate. Take them apart initially, deburr, lubricate, reinstall with red Loctite. Then inspect the shaft and lubricate yearly (high temp grease) and you *should* be fine. OBX makes some of the better china WG’s I’ve seen. They don't appear to be the same re-badged gate castings sold by EMusa, godspeed etc...
2 38mm gates are plenty! The larger the gate the less control you’ll have. I can regulate a single 1.25 T4 with a divided 2” hotside (38mm on each side) down to 8lbs. Less if I installed a lighter spring. Twins will have less drive pressure than most singles and require less gate diameter.
Old 10-27-2015, 11:40 AM
3 window's Avatar
Try and contact wicked69. His car flat out hauls! He definitely got the twins figured out. I believe I read he started with the on3 stuff. Very knowledgeable guy. Give him a shout. It'd be well worth it.
Old 10-27-2015, 01:16 PM
BOOSTAT4500's Avatar
The on3 70's will easily meet your goal of a mid to high 9. I have them on my SBE 6.0 and ran 10.2@142 at 7000' DA a few weeks ago. Launching at only 2 psi and 3400 race weight. Once I get a few other things situated, it should run a 9 up here.
I have twin 38mm wastegates on it and can hold 4 psi (spring pressure) boost no problem.
Old 10-27-2015, 04:13 PM
toytech93's Avatar
I'm curious how much boost were you running to get 142mph ?
Old 10-27-2015, 04:58 PM
14-16 pounds peak. At about 1000', my rear tires started rubbing the rear bumper so it would load and unload as the car got a little bouncy. My converter is also about maxed out, 15% slip in high gear, so that wasnt helping either. This combo has a lot more in it once dialed. I think the OP would be pretty happy, and it was cheap.
Old 10-27-2015, 06:46 PM
vht
vht's Avatar
I need cheap right now. I heard the OBX gates were good. I got a lot of room, don't think I'll have a problem there. I'm sure I'll need some help when I get started. Soon as more money comes along, I need to pick up a cam, Ls7 lifters and a set of springs. What timing chain do you all run?" Also, been wanting to ask about the eng valley cover. Seen some on ebay, knock sensor delete. Also wondered if I should vent the crankcase from there or a hose from each valve cover to a tank. So many questions.
Old 10-28-2015, 08:19 AM
Forcefed86's Avatar
For the same cost the 76mm flows more air than the 70mm and 6.0 guys are having zero troubles spooling them. You can make your power goal with smaller turbos too, but they will be working harder and heat the air more. (less efficient) China turbos are already crazy inefficient compared to the new turbos. I’d want more wheel diameter personally.
You can get the new style LS3 GM lifters for $90 shipped to your door on ebay.
http://www.ebay.com/itm/New-GM-Hydra...hTcibJ&vxp=mtr
12646386 is the newer heavy duty GM chain. It’s a nice OEM piece. Used with new factory gears that’s all you need. Stay away from cheap autoparts store timing sets! Better off with the original 100k+ mileage set.
http://www.ebay.com/itm/GM-OEM-Engin...BV52GF&vxp=mtr
If you want the ability to adjust cam timing and plan to degree the cam (Which I suggest doing) the Cloyes single adjustable billet roller is nice and not super expensive. Around $160 for the set. I’ve seen several aftermarket cams needing big adjustment on the newer gen4 engines.
Valley cover vents are nice, but not needed if you’re on a budget. Newer engines shouldn’t have the knock sensors in the valley cover, thy should be on the block. Even if it does, silicone the rubber covers in place, remove sensors and move on if you don’t plan to use knock sensors.
Quick Reply: Turbo suggestion for twins
