High Altitude Boosters Please Help
Old 10-26-2015, 11:47 AM
billbillracing's Avatar
Default High Altitude Boosters Please Help
I am at 4200 feet of elevation regularly the track is 6k-7k DA.
I am in the process of piecing together a turbo kit for my TBSS.
I am going to be staying with a stock bottom end for a couple years so boost will only be 8-12 lbs.
I have picked a front mount S475/83 t4 I just cant figure out what size a/r to go with. My tuner is saying .86-.94 because of elevation forced inductions is saying 1.10-1.25. Bullseye is saying 1.0-1.10
I know the turbo has to spin faster at higher elevation to make the same boost. Which would me more possibility for lag if the a/r is too big right?
What are other high elevation guys running for a/r ? I am going to have a cam specced for my build so I have to figure everything out so I can pass it along.
I will have a 3200 FTI stall also not sure if that matters
Old 10-26-2015, 01:45 PM
IronBlocked's Avatar
If you're not going after every bit of air the turbo will put out, get the smaller A/R, although I feel I'm wrong when contradicting FI's advice, specially given the smaller turbine wheel.
Old 10-27-2015, 12:31 PM
Forcefed86's Avatar
What engine? What kind of RPM? Trans brake? 1/4 mile? 1/8th mile?
Actual stall speed made by your engine plays a big roll. "3200 FTI" stall doesn't tell us much.
Old 10-27-2015, 02:03 PM
LJMSJohn's Avatar
1.10 with a small cam will be fine...
Old 10-28-2015, 04:09 PM
2BAD4U's Avatar
From the sounds of it. You might be in Utah? Lol I am at 4,200ft good day DA 5,800 1.10ar will be fine. Especially in a auto car. Spool will not be a issue. I'd assume you start seeing boost by 2,800 to 3k
Old 10-29-2015, 01:42 AM
9 Second Truck Club
stock48's Avatar
That S475/83 will work really well in altitude. 4200' is not too bad. I race in denver a lot and it's 5900' and 9000+ DA. Like John said need to keep the cam conservative and a 1.15~1.25 AR will be fine on the T4. I have a S475/83 1.25 T4 on my lq4 with My triple 12 cam and it's been bottom 10's in Colorado @4850 lbs, spooled well. Have ran mid 8's in the nova with a similar combo with the billet S476/92 1.25 T4, and my 218 cam and it worked really well in the high DA. My new combo with the Billet 76/96, and ported 1.25 T4, with mid 220's cam is really laggy up there with a 3400 converter. FTI has a few pretty good conveters but you will definitely want it to be a turbo converter. The Na converter will be a bit tight down low and loose once turbo comes in.
Old 10-29-2015, 01:51 PM
gpr
gpr's Avatar
If you don't mind me asking, what are the specs on your triple 12 or 218 cam? I have a turbonetics 78/75 turbo at high elevation, and the ls1 already had a cam in it (don't know the specs) and it does not spool very quick.... Looking for a new turbo cam that has a nice chop and quicker spool.
Old 10-30-2015, 11:21 AM
turboventura's Avatar
I live at 8600 and race/drive in the Denver area a lot. I have an L33 with ljms 218/223 cam, s480 with 96 turbine and 1.10 ar, 2.25 divided hotside, 3200 PTC converter and 3.23 gear, spool surprised me, works well.
Quick Reply: High Altitude Boosters Please Help
