Supercharger with my setup?
Hi guy, I`m looking into buying a procharger system but was wondering is this is possible with my setup.
My car is a 2000 m6 ss
Hooker long tubes , ported throttle body, ls6 intake, lid, si5 cam, pac racing springs. I`m a little worried about the cam .
I`m not looking for big power 450-500hp, not looking to forge the internals.
Restricted User
450-500 to the wheels, or flywheel? Flywheel can be done with your current setup fairly easily.
A procharger setup is pretty damn expensive to only gain 100 HP. I spent a quarter of that to gain 500 HP.
LS1Tech Premium Sponsor
A P1SC kit at 8 pounds will work great and the cam is fine. This will still run on pump gas but I'd suggest a custom tune when you are set to go.
Give us a call we can supply you with all the necessary parts, cooler, bumper support, and any other necessary items to support the supercharger install. We also guarantee the lowest price and excellent tech support to make the deal that much sweeter!
Restricted User
This isn't the 70's. There are guys making almost twice that on a stock bottom end.
The record for a stock bottom end LS1 is somewhere in the 800s. The truck motors are making a lot more power. The gen 3 rods are weaker, so I wouldn't go above 650whp or a bad tune will cause you to have bad rods, but at ~8 PSI on your current setup you'll make ~550 to the wheels on pump gas and it still be very very reliable with a good tune.
It is.
Alot of people here think E85 fuel is sold at every gas station in every state and think nothing to say "Stock bottom end and 700rwhp" in the same sentence.
If you got E85 fuel in your area, yes you can make crazy power on a stock bottom end.
If your like me and got 2 gas stations that sell it and both are 45 minutes away. Not worth it. Go with a forged bottom, 93 + meth, make big power and and have peace in mind.
Were I live we don`t have e85, but my car is only used once or twice a month for a little racing, nothing big. but I run 114octane vp racing fuel so that will be no problem
Restricted User
It is.
Most people believe the power is in the octane, others know its in the tune.
I've been throwing around the idea of going the turbo route in my 45,000 mile LS1/WS6. I've been back and forth on pulling the LS1 in lue of a junk yard 4.8 or 5.3, but since I already have a good, low mile and solid LS1, I might as well just use it. I'm sure the 4.8 or 5.3 can safely handle more boost/power than the LS1, but how much more, that's the question. I'm not looking to break any records or anything, but would love to have 700+ HP.
Your stock bottom end will handle the P1SC at 8 pounds of boost all day long, and with proper tuning can be ran on pump gas with no issue. The LS engines are very stout, there are a lot of people running insane times with stock blocks, rods, and pistons. Nick Mobus has been a string of 8.0s @ 170+ with a stock bottom end 6.0 running 20 psi.
Give us a call... we would be glad to help out.
