98 Formula "Phoenix" Mp76, Sbe 6.0/t56
This is my 98 formula. Going with a stock long block '04 6.0 with a 228/228 @.588 on a 116+3 cam, Master Power 76 Turbo, Tial 44 mm wastegate/Tial 50mm BOV, and custom Truck Manifold hotside. I'm going to update with photos As they come. As of now I have the Radiator core support notched, and boxed for a Lt1 Fbody Be cool radiator. It's going to be a pic heavy thread, and I'll gladly answer any questions you guys have.
The fuel system is Going to be a Walbro 340 intank with Siemens 60lb injectors. Shooting for 500 whp with room to grow. I plan on using factory fans of they'll fit, and relocating the battery to the trunk to free up some engine bay space. I also plan on removing the ac part is of the heater box, and retaining heat.
Here is a price list for what I have spent so you guys can get an idea or how much it costs.
Total so far ~$(2953)
Still need :
-Decent Wideband
-New or Barely used Ls6 oil pump
-ls9 gaskets
-Hardened pushrods
-walbro install kit
Total invested :
600- 2004 Lq4 with 176k, after parting the van
330- Fast 78 Had to repair Flange though.
400- Used MasterPower 76 with a .96 Ar
220- Turbo Cam Used, 228/227 @.588 lift 116+3
220- Used Be Cool Lt1 radiator
350- Used Siemens 60lb injectors and new Walbro 340
100- Used CBR alt. relocation bracket
40- solid aluminum motor mounts.
100 - for a Harness rework so my 98 can run a 0411 pcm
100 - Turbo flange and 2.5" vbands (stainless)
235 - Decided to buy a TIAL 44 mm Wastegate.
400 - more hotside. Stainless isn't cheap lol
70 - Arp Headbolts Used
80 - ls7 lifters
50- used Xspower 3" in and out intercooler
100- dual Valvesprings from a friend
150- More flanges, v-bands, couplers etc.
160- Tial 50mm Bov
Still need :
-Decent Wideband
-ls9 gaskets
-Hardened pushrods
-walbro install kit
Total invested :
80 - ls7 lifters
160- Tial 50mm Bov
So it's been a while but I have been making progress. Painted the 6.0 and put all of the Fbody accessories on it. I plan on swinging the engine in in the coming week.
I find that even the small victories are key to moving forward. I haven't got to work on my car during the winter, but a couple hours completely changed my outlook.
So I finished the hot side up to the turbo today. V banded the truck manifolds. And put the o2/wastegate flanges on. 2.5" to a 3" merge to the t4 flange. Used 1.75' pipe for the wastegate.
Put the turbo where the battery sat. The cold side is going to easily shoot through the fender / bumper and am going to mount a FMIC . Haven't decided on where the cold side outlet is going to run.
Used DEI titanium heat wrap on the stainless hotside, and 100' seems to be about how much I'm going to need. It's very easy stuff to deal with. Going to run a 3" downpipe under the motor mount and I may even run a cat converter.
This isn't a terribly difficult thing to do. If you can weld it's totally attainable for the average dude
Started Cold side fabrication. Cut out the bumper to start a mount for the intercooler. Going to use 2.5" stainless bends for the cold side because I have some lying around.
Recently purchased a Tial 50mm waste gate. Finished 99 percent of cold side fabrication, and started messing with the down pipe. I decided to space the front swaybar down to ease fabrication of the down pipe.
