What turbo will fit where my PT76/75 .96ar is??
Hey guys, im looking for a turbo with more potential than my PT76/75 and that it wont require a lot of modifications..
Any advice??
Thanks!!
Any advice??
Thanks!!
Ive gone over 152 running out of gear with a 7675 at only 15psi
It might not make a thousand but itll probably do close
Any reason behind the 4 digit power goal other than wanting the number?
The pt7675 will hit mid-low 6's. If anything, consider a larger downpipe if you are currently running a 3". I only upgraded to the larger turbo because my friend had it laying around and it fit perfectly so he cut me a deal.
Thanks guys! I already order my second walbro 400 and a hobbs switch to turn the second pump on when I hit boost and we plan on pushing it harder than 12lbs on VP race fuel and meth injection.. Hopefully I get in the 18-20psi range..
I think everyone missed the part where you are a 370ci. You will probably start fighting back pressure very quickly after you turn the boost up. That will be your biggest challenge.
Downpipe being 3" will prove to be the bigger restriction than the turbo on a 370". In my opinion that turbo has a lot to offer. Get a 3.5-4" downpipe and it will handle 20+psi well
I don't have any concrete data to substantiate what I was running into but I was seeing diminishing gains after 16psi on my 3" downpipe. I feel as though i was choking on back pressure with a 5.7. The plan was that I'd do the bmr turbo kmember and run a 4" on the PT7675 but I decided if I'm going through all that I may as well use my buddies turbo since it was right there.
