LSX 5.3 into Nissan S chassis
#41
Well the turbos are in. Everything is just tacked to mock up mild steel flanges for now. Picking up 10 stainless laser cut flanges tomorrow from my water jet guy and will final weld everything. I wish the turbos were mirror image so the hotside would look the same on both sides. The driver side flange is up top and look beautiful and clean but the pass side flange is down look and required a few extra bends to mate up. Still looks good tho
#43
Originally Posted by kingtal0n
I missed it, what happened to the truck manifolds? Where did you get those shiny new lookin ones? also curious why the pie cuts, for looks?
#44
Few little things I did this week. Got flanges and 3" in them. Took a while but I developed a technique where the 3" tubing into the t4 flange fit perfectly no gaps and looks very nice.
Also drew up and cut some 304 grade stainless steel with my newly opened side business thing? Idk what to call it just yet logo. 1"x4" And says Turbo Craft. will weld on future project to tag my work. Came out killer as well. Also some new shirt ideas for Turbo Craft. If anyone wants to purchase any of the flanges to t4 and tubing welded or unweeded and you can weld them yourself I will also be selling a few. Limited supply for now. Flange is 1/2" cold rolled and tubing is 3" 304 stainless. Priced very fair!!
#47
Did a few things. Working on a parachute mount. Still not done with it. Might re do it i have a few new ideas I want to do
Got new wheels too and some 275x Mickey Thompson
#49
glad to see you wearing your respirator! hexavalent chromium is some nasty ****.
my new years resolution is to wear mine 100% of the time at work.
#51
Originally Posted by 1500HP
Looking good boost I definitely like the roller , I was kind of in your area a day or so ago was in fort Washington,
#53
Finished up a few parachute mounts today. 2
For customers one for my car. If anyone needs a basic chute mount let me know, very reasonable price.
Drilled all the spot welds on the front end, getting ready to do some tubing work.
#54
I am curious what you will do for accessories. Holley makes a bracket kit that will allow you to use truck accessories, but I do not know if that fits a 240sx. Another company, "LSsimple" also make a similar kit, and again I don't know if it will fit the 240sx. Both move the accessories for 'engine swaps' I believe, I am still doing research so I don't know enough yet, .
#56
I had used the CTSV drive on my S14 setup since it "hugged" the accessories closer to the block. Used a Vette balancer and has a decent amount of room. My buddies did it with the GTO drive as well...just had a little less room.
Still loving the build man. Living vicariously through your build Boosted.
#57
Thanks man it's been slow progress thus far, but I have a feeling its going to get finished sooner than later. Just picked up a e36 vert and doing a full cage and m52 swap on it so I can drift it this summer. Really excited about that as well.
#59
The beginnings of the tube front end. Am trying to keep most of the OE sheet metal but will be making some ally panels that with be held in with dzus clips for easy removal. Few pics. Still need to cnc cut some front supports but fenders, headlights and good fit great.
Also made the front hoop removable with a few connectors that secure with 2 10m x 1.25 button head bolts.
