D1SC procharger fill hole in correct location??
I have a 93 Mustang and have a GTO bracket setup but the head unit was bought elsewhere, I know I can clock the volute, and I can get the slinger in the correct position but the fill hole looks like its to far over? or is this ok. Not sure as never had a procharger
8 Second Truck Club
Typically the ID tag on the blower is an indication of where the slinger is. If the slinger was moved, the tag should have been moved as well. Need to open the blower up to check it out for piece of mind. The tag needs to be pointed up otherwise you will have a garbage blower shortly.
LS1Tech Sponsor
I agree with everyone that posted, pull it apart to make sure. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
ok thanks, the drain is right at 6 and I already pulled it apart to move the slinger to the correct location. So I guess the fill hole is ok then. Might have to clock it a little more so I can access the drain as the allen bolt is right in the way.
I know the drain is good like I said I pulled it apart and have moved the slinger to the correct location and checked where it drains. Just wasnt sure of the fill hole but I just saw one this weekend and his was to the side also.
thanks for all the responses, always appreciate.
