S484: Griffin 58241 XLS issue
Old 11-22-2015, 03:54 PM
boss79z's Avatar
Default S484: Griffin 58241 XLS issue
I have about 230 miles on my new setup. S484 T6 Huron Speed Kit with an Forged Alum 346. I am running the Griffin 58241 xls radiator and I can't seem to find a leak it has. I have checked all hoses and it they are clean. It continues to have some seapage underneath the radaitor onto the support.
I am also running the Kurt Urban Steam vent system. I was just curious if everyone had as much coolant in there as I do mine. When I ran the water vapor system on my stock LS1, I don't remember it ever really having coolant in it. Wondering if other users are seeing the same thing in there water vapor system and/or if they had ideas for the coolant leak that I am not thinking about.
Below is a picture of the setup. Cage, AFCOs, and chute go in next month.
Attached Thumbnails S484: Griffin 58241 XLS issue-andrew-motor.jpg
Old 11-22-2015, 11:47 PM
SPRAYED 01's Avatar
Jesus that turbo looks bigger than the engine!!
Old 11-23-2015, 09:10 AM
transam69230's Avatar
Couldn't you just pressurize the system using the correct tool and find your leak?
Old 11-23-2015, 04:32 PM
boss79z's Avatar
Pressurized the system when we put the coolant in. Had no leaks that were noticeable then. Went through everything again yesterday and I think the end tanks have a small crack in them.
Quick Reply: S484: Griffin 58241 XLS issue
