Derale 16925 fans an racetronix dual fan kit guys
Old 11-23-2015, 07:23 PM
blkgagt94's Avatar
Default Derale 16925 fans an racetronix dual fan kit guys
So I have to derale fans wired up all power an grounded an I have them
Both running off high at same time grounded off ecu an it keeps popping both 30amp fuses an they pull 23.40amps any of you guys know why?
Old 11-23-2015, 08:55 PM
old93camaro's Avatar
yes when they first come on they draw close to 40- amps, you have to run 40 amp fuses
Old 11-23-2015, 10:45 PM
98Camarod's Avatar
I had to stagger the temps that they would come on and didn't have a problem after that. Well, after I replaced the POS fuse holder they come with too.
Old 11-23-2015, 10:48 PM
Deeohgie69's Avatar
My car had stock 40amp fuse and when both derale fans came on it kept popping the fuse. I threw a 50amp fuse in and haven't had a problem since.
Old 11-24-2015, 09:36 AM
http://www.amazon.com/Bussmann-BP-CBC-40HB-RP-Circuit-Lengthwise/dp/B004AH4PDW/ref=sr_1_1?ie=UTF8&qid=1448379321&sr=8-1&keywords=40+amp+circuit+breaker http://www.amazon.com/Bussmann-BP-CBC-40HB-RP-Circuit-Lengthwise/dp/B004AH4PDW/ref=sr_1_1?ie=UTF8&qid=1448379321&sr=8-1&keywords=40+amp+circuit+breaker
cant go wrong with a auto reset 40amp
Quick Reply: Derale 16925 fans an racetronix dual fan kit guys
